IDM Mod with PHP tuning????
Old Feb 5, 2016 | 08:59 PM
Truck815's Avatar
Truck815
I am about to order my tunes from PHP. I was told by my local powerstroke shop that if I run the Tunes with the IDM mod, I will lose power. However, I called PHP and they said they have never heard of this being an issue. They suggested I call Swamps diesel since they both the PHP tunes and their heigher voltage IDM. Swamps said "no problem". They said the tuning and IDM mod are different things and the IDM mod will only help me and not hurt me.
I want to do the IDM since the resistor is .25 cents and I can gain 20hp
Please advise
Old Feb 5, 2016 | 09:05 PM
97-psd's Avatar
97-psd
Do it. I had it with my DP tunes with no issue. Like swamps said. They are different kinds of mod with no real direct relation
Old Feb 5, 2016 | 09:11 PM
Truck815's Avatar
Truck815
Did you do both at the same time? Could u tell a difference IDM? I assume u swapped in the 75k or whatever it is resistor?
Old Feb 5, 2016 | 09:35 PM
97-psd's Avatar
97-psd
I had the IDM first for awhile then added the DP tunes. I can't remember which resistor I ended up using. That IDM died and I didn't have time to upgrade the new one. It is on my list of things to do. The truck did seem to run smoother with it in
Old Feb 5, 2016 | 10:01 PM
Truck815's Avatar
Truck815
Great. It's a cheap mod. I need to find a good write with pics. I saw one the other day.
Old Feb 6, 2016 | 02:45 PM
richdawg's Avatar
richdawg
This is and old link, you might find it interesting
https://www.ford-trucks.com/forums/8...-140-volt.html
Old Feb 6, 2016 | 09:10 PM
Truck815's Avatar
Truck815
Thanks a lot. I don't know why my local shop told me that but I will go ahead with the mod along with my PHP tunes I think. Thanks guys
Old Feb 7, 2016 | 06:20 AM
427 fordman's Avatar
427 fordman
The idm mod is a decent mod, but it WILL shorten the lifespan of it. Mine lasted a couple years after the mod, now I just run a remanned 120v off of a SD.
Old Feb 9, 2016 | 07:11 AM
Truck815's Avatar
Truck815
I just get conflicting Opinions on it. Swamps says yes and DP Tuner says it's nott really a HP mod
redman84
Jun 29, 2010 08:42 PM
rat49f6
Apr 2, 2009 05:57 PM
eric777
16
May 23, 2007 06:31 PM
nickle&dimeya
Feb 10, 2007 08:28 PM
