codes after installing modded IDM - normal or problem?
Old Mar 20, 2012 | 01:15 PM
SkySkiJason's Avatar
SkySkiJason
I put in a used Swamps high voltage/high freq IDM. The truck runs like a bat out of hell. It seems like the off-idle power and throttle response are much better - the truck doesn't bog down at all letting the clutch out. No complaints about how this thing works at all.
Hooked up the AE to check some other things and got a bunch of codes when running KOER, CCT, etc. (6) injector high to low side open codes, IDM fault, L & R bank high side open, etc. None of this sets CEL and like I said there are no performance issues - Should I be worried?
I have also intermittently seen P0220/P0221 TPS codes (this sets CEL). Is TPS giving me a clue that 342k miles is long enough?
<!-- / message --><!-- sig -->
Old Mar 20, 2012 | 01:23 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I never did the IDM mod, but Roland put his back to the OEM IDM. He said his truck runs better with the 120v then with the 140v mod. I'm sure he will get on here and tell you why he did that.
Old Mar 20, 2012 | 02:25 PM
MauleOne's Avatar
MauleOne
IDM
I went with the Swamps IDM when I replaced my injectors just to make sure the old IDM wasn't a problems.
No codes from IDM that I am aware of ....yet
Old Mar 20, 2012 | 02:57 PM
Robert6401's Avatar
Robert6401
All I can say is that my Swamps IDM has worked fine since the day I put it in, all the benefits just like you described.
Old Mar 20, 2012 | 03:15 PM
Studawg's Avatar
Studawg
Thread Ender
Man, I just dont get IDMs. It seems like it is a complete crap-shoot any time you are dealing with these things. There doesnt seem to be any rhyme or reason to them.
Old Mar 20, 2012 | 10:55 PM
mueckster's Avatar
mueckster
I had the DIY 140v IDM mod. It was great with stock injectors (saw increase in mpgs/power), but the throttle response was overly sensitive after going to larger singles. My truck was a PITA to drive on a rough road. I drive on a ash haul road to our shop 5 days a week and I had my fill of the surging and bucking. The 120v tamed things back down and my mpgs didn't suffer. I did, however, have another experience with my reman IDM replacement. The one I have now throws a code P1298, but seems to be working fine. I can get maybe 1 out of 10 buzz tests where it passes without the codes. I just don't worry about it much since it runs great.
185pilot
Feb 6, 2016 04:59 PM
fordpride
Dec 30, 2011 11:13 PM
jmaskew
Aug 21, 2011 05:47 AM
ZeroAccess
Sep 15, 2008 04:07 PM
blrman1962
May 27, 2007 11:10 AM
