Computer?? Again?!?!
Old Dec 4, 2013 | 11:09 AM
99F350bigorange's Avatar
99F350bigorange
Just got a new PCM for my 99 F350 everything has been fine and dandy until today. Let it warm up for about 15 minutes, it was plugeed in, since it is -5 here today. Got a few blocks down the road and the truck shut off out of nowhere. Won't start acts like the computer is froze up. This exact thing happens if I'm programming the truck with my edge chip and it unplugs. When this happens I call them and they send me a stock writer however, this time they say it cant be the chip since I was driving and they cant help me basically. Any suggestions? Or another new PCM? Thanks!
Old Dec 4, 2013 | 12:19 PM
clem1226's Avatar
clem1226
are you getting a wait to start light etc?
my first thought at -5 is gelled fuel.
Old Dec 4, 2013 | 12:30 PM
99F350bigorange
No wait to start light. That's what's got me leanin toward some kind of electrical problem.
Old Dec 4, 2013 | 12:33 PM
clem1226's Avatar
clem1226
Do you have power to the PCM? Do you still have a fuel bowl heater and is it hooked up?
If you still have a fuel bowl heater and it is hooked up check fuse 30 in the iin cab fuse box. If it is blown unplug the fuel bowl heater on the back of the fuse box and replace the fuse.
https://www.ford-trucks.com/forums/1...wts-light.html
Old Dec 4, 2013 | 12:37 PM
99F350bigorange
My chip comes on and says no communication to with the pcm and gives an error. Not sure if I still have power to it or anything. I'm at work now had to tow it back to the house and leave the tests for tonight. If I Do anything tonight being that its only getting windier and colder right now. I will start with checking power to the pcm though
Old Dec 4, 2013 | 12:39 PM
clem1226's Avatar
clem1226
I edited my post above and added a link, sounds like it may just be a simple shorted fuel bowl heater.
Old Dec 4, 2013 | 12:44 PM
99F350bigorange
I will dediny start there! That would be awesome!
Old Dec 4, 2013 | 01:05 PM
SpringerPop's Avatar
SpringerPop
Given the extreme cold, it could also be a "sticky" PCM power relay. Under-hood box (I believe for a '99):
It's the top one in the row on the right.
Also, the IDM relay is the third one down.
The washer pump relay is the fourth one down, so use it to swap into the other positions to test.
Pop
Old Dec 4, 2013 | 02:22 PM
BillyBob69's Avatar
BillyBob69
The fuse for the fuel bowl heater/PCM is the bottom one, second column from the right, on the under-dash fuse box. 30 amp fuse. I believe the ONLY 30 amp fuse in there. If it is blown, unplug the fuel bowl heater (White plug at the back/bottom of the fuel bowl), then replace the fuse and try again.
Old Dec 4, 2013 | 06:22 PM
99F350bigorange
I found the fuse and it was blown!! That's good I think haha However while I was at work I didn't have my truck plugged in, idiot, so no its -13 and my EOT is 12. I fixed everything you guys said and the Wait to start light comes on and my pcm responds now! After the oil warms up and everything else I will give it a whirl and let everyone know if that works. Thanks everyone!!
Old Dec 4, 2013 | 09:22 PM
clem1226's Avatar
clem1226
congratulations!!
I am glad it was that simple.
Old Dec 6, 2013 | 11:51 AM
99F350bigorange
And it starts and runs again!! Doesn't like the -30 temps but deals with it for now haha. Thanks again everyone!!!
Old Dec 6, 2013 | 12:12 PM
BillyBob69's Avatar
BillyBob69
Good to hear it is back up and running again.
I did mine during rush hour in the middle lane of a 5 lane highway. YIPPIE!!!
At least it doesn't take much to do it. Now you can work on getting a new heating element.
Old Dec 6, 2013 | 12:15 PM
99F350bigorange
Im gonna get one coming but may wait until we see positive temps again before replacing it thats for sure! Haha
coreymck
13
Nov 30, 2012 10:41 PM
Bird Dog
22
Feb 17, 2011 07:26 PM
bigfordandjeep
15
Apr 6, 2009 09:18 PM
bens99f350
Jan 29, 2009 03:30 PM
clajoie
17
Apr 26, 2008 11:51 AM
