please read
Here is one forum discussing the issue related to harmonic balancers and exterior influences on the crank.
Crank Failures, mainly pre 85? [Archive] - TheDieselPage.com Forums
This article says the 6.9 crank uses exterior mounted weights to balance the crank. If weights are used on a flywheel I would assume the bolt pattern is keyed in some way or you must replace the flywheel in the same position if you ever remove it. "....External balance weights in the flywheel and a vibration dampener were required to keep the overall engine size within that of a gasoline engine and to limit the scrap rate during manufacturing...."
International 6.9L Engine - Diesel Power Magazine
https://www.ford-trucks.com/forums/1...aft-pully.html
https://www.ford-trucks.com/forums/1...ken-crank.html
http://en.wikipedia.org/wiki/Harmonic_balancer
Last edited by Dieselamour; Dec 15, 2013 at 06:54 PM. Reason: I thought he had a 6.9/ added info
