Lab Report Blues
Old Apr 19, 2013 | 09:51 AM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Lab Report Blues
I will post up the report later, but it is indicating I still have a coolant infiltration into the oil. No sign of oil in the coolant. I have replaced the oil cooler O-Rings and gaskets. I am guessing that the next course of action is going to be to pull the injectors in preparation for replacing the O-Rings. While in there, inspect the injector cups and see if there is a crack in any of those. If that doesn't cure it, I guess the next course will be to look at the front cover. The interesting thing is that I am not showing any oil in the coolant.
Old Apr 19, 2013 | 12:11 PM
twg1966's Avatar
twg1966
http://i1337.photobucket.com/albums/...g?t=1366391395
Here is the report received yesterday. I am going to go ahead and do several things at our tech day, hopefully, I can find what the cause may be for the coolant issue.
Old Apr 19, 2013 | 01:56 PM
jeffreyt's Avatar
jeffreyt
Ted try to pressure test your coolant system and see if it will hold pressure over night. If the coolant is getting to the oil there should be some bleed down. If it holds, I'd guess that maybe the report is giving a false positive for some reason. Mistaking a trace of something else as coolant maybe???
Old Apr 19, 2013 | 01:58 PM
jeffreyt's Avatar
jeffreyt
I tried to read the report but it was too blurry on mobile.
Old Apr 19, 2013 | 02:03 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Did you do the oil cooler o-rings before or after the report?
Old Apr 19, 2013 | 02:35 PM
honeydew's Avatar
honeydew
IMG link
Old Apr 19, 2013 | 03:02 PM
jeffreyt's Avatar
jeffreyt
So it doesn't appear to give a value of antifreeze, only "POS", which I'm hoping means positive and not their reference to your engine...
So it could be showing smaller traces each time, but still giving the same positive result. Have you been changing the oil in the HPOP too? Maybe traces there that are contaminating the rest of the oil.
And thanks for posting that Travis, much easier to read
Old Apr 19, 2013 | 05:27 PM
twg1966's Avatar
twg1966
Thanks for helping me out with that posting Travis. I couldn't figure out how to post a PDF. The oil cooler o-rings were changed after the second analysis. Was hoping this one would have shown a cleaner report.
bunklash
Apr 10, 2019 07:39 PM
Jesser02EX
Dec 29, 2015 07:22 PM
grizzly11
Nov 20, 2010 12:29 PM
Flobber
Aug 7, 2008 12:19 AM
bstarroilburner
Oct 16, 2005 07:40 PM
