injector cup
Not usually. The most common thing that allows coolant in the oil is the oil cooler. It is a pretty easy fix.
Here are the parts from Diesel O-Rings.com there is also a PDF on how to do it there.
Not all the time. The coolant stays pressurized longer than the oil once the engine is shut down. Depending on your oil pressure the coolant pressure may be higher at idle. It may be just enough to cause this.
i found the paper from the dealer and it said they did a coolant check and found combustible gases in coolant. after i took passenger side head off the front piston was ghost white compared to all the other ones. The only reason im ruling the cooler out is that you would be fighting the oil system and the air is got to go back through the system to do so and the piston kinda numbered out the cooler i will fix it if it does not fix the problem
