e4od c6 ECU
Old Nov 20, 2013 | 09:53 AM
redrivergorge's Avatar
redrivergorge
e4od c6 ECU
I'm trying to sell my 88 E350 and the heater core took a **** on the ECU. I've put a new motor in this truck out of a 91 E250. I saved the computer from the donor truck. Will the E250 computer work besides throwing codes because it doesn't see the trans? The wiring harness was different on the 91 but the ECU pin out is the same.
I'll never get what I have in to the E350 out of it so I just want a cheap way to get it running. I'll tell the buyer what I did and why its throwing codes.
The 88 has a 351w w/c6 F8TF-12A650-AU1B
The 91 had a 351w w/e4od F2TF-12A650-LA
Old Dec 6, 2013 | 12:36 AM
archangel's Avatar
archangel
I do believe to pull the E4OD out and swap in a C6, or install an engine that had the E4OD, you need the manual trans ECU for that same engine so it is not looking for the E4OD signals.
Old Dec 6, 2013 | 12:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it should work, except it will turn on some lights and set some codes.
fjazzbass
May 9, 2015 08:58 AM
jsalveson
Dec 16, 2011 11:07 AM
sturgem
Aug 11, 2010 11:07 PM
oldmansimek
1978 - 1996 Big Bronco
13
May 30, 2008 02:55 PM
potatogun
Sep 5, 2007 10:34 AM
