transmission
Old Aug 6, 2010 | 12:51 AM
sturgem's Avatar
sturgem
transmission
i have a e4od in my 91 can i put a c-6 in it
Old Aug 6, 2010 | 02:42 PM
Lazy K's Avatar
Lazy K
Yes it is possible.
Old Aug 6, 2010 | 02:54 PM
jas88's Avatar
jas88
That would actually be the easiest swap to a non-E4OD trans. The E4OD is based on the C6 so they are pretty similar. You can even use your existing computer, it will throw about 6-8 codes complaining about the trans, but it won't turn on the CEL over it. The C6 is a little shorter than the E4OD I believe so you will need a different driveshaft or have yours lengthened.
Old Aug 6, 2010 | 03:15 PM
White 97 xlt's Avatar
White 97 xlt
I'm sure you are aware you will not have overdrive with a C6.. Won't be much of a problem with local or city driving, but it will kill your fuel mileage on the highway...
Just a thought....
Old Aug 11, 2010 | 11:07 PM
sturgem's Avatar
sturgem
thanks for the info that might help its my sons truck waiting for him to make up his mind on what he wants to do might need some more advice if we do this
