1978 - 1996 Big Bronco
C6 to E4OD in 85 Bronco?
Old Oct 8, 2005 | 09:53 AM
oldmansimek's Avatar
oldmansimek
I have an 85 Bronco 351w H.O. It has a C6 in it right now that is in it's final death throws. My buddy is junking his 90 F-250 that has a brand new E4OD in it I was wondering if the swap is possible since the E4OD is electric with no kickdown any advice would help. the E4OD is bolted to a 351 right know
Old Oct 8, 2005 | 10:09 AM
masseysbronco's Avatar
masseysbronco
well if the the engine is good in the 250 grab both, and it will work. the E4OD needs all kinds of signals to work cause it's fully electronic so it won't work on an old carb engine.
Old Oct 9, 2005 | 02:27 PM
greystreak92's Avatar
greystreak92
Masseysbronco has it right, the E4OD will need the correct computer to control it and the computer will only work porperly with all of the engine sensors feeding it information as well. Unless you feel like swapping wiring harnesses and adding a computer-driven power plant, you would be better off with another C6 or even an AOD (if you want an OD transmission) since adding the TV cable/linkage for it would still be less trouble.
Old Oct 9, 2005 | 04:21 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Does Baumann engineering still exist? They used to offer a stand alone computer that would allow an electronic Ford tranny to be installed behind anything.
Old Oct 9, 2005 | 09:16 PM
oldmansimek
Thanks guys I didn't think it would work but it was worth asking. I'm just going to swap it to manual trans much easier and cheaper since I have everything to do it anyways thanks again.
Old May 30, 2008 | 12:47 AM
dutchlincoln79's Avatar
dutchlincoln79
Why is everybody so incredibly afraid of installing a few wires even with included schematics?
Almost every thread the E4od is rejected or not-adviced, because of the " huge" trouble to get trough due to some wires...
Just take a look at the baumannator website, and find that it's actually very very easy... (and in my opinion, even better than fabbing a TV linkage...)
Its like people are afraid of things they don't know, or don't have knowledge about...
Old May 30, 2008 | 01:20 AM
greystreak92
I wouldn't be afraid of ANY number of wires if the E4OD were worth even considering for the transplant. Its a worthless hunk of scrap! It can't handle the torque from anything bigger than a bone stock 351 (5.8) and even the latest internal updates make it good for about 60-80K miles before it detonates! It has absolutely NOTHING to do with electronics. Electronics are my forte, I would embrace it whole-heartedly if it weren't mechanically inept. I would much rather re-calibrate an MLPS than tweak a TV cable myself but why bother if all the calibration in the world will still only yield a mediocre piece of equipment?
Old May 30, 2008 | 08:45 AM
jas88's Avatar
jas88
That's an unfounded rant based on my experiences. My E4OD has 243K miles on it and it still works perfectly. I also put 155K on an Expedition with the 4R100 in it (same trans) and it was still working great when I sold the truck. Ford put the E4OD behind 460s and Powerstrokes so I think it can stand up to more power than the 351 can muster. The E4OD was based on the C6 so I don't think the design is a problem.
Old May 30, 2008 | 09:24 AM
Conanski's Avatar
Conanski
The design isn't the problem, it's that people think ALL transmissions get the exact same internal parts for every motor and vehicle, when nothing could be further from the truth. The E4OD that goes behind the 460 is much stronger than one for a 5.0 for example, it gets more clutch plates and bigger servos and bands. Any of these trannys can be built to handle whatever you want to throw at them, it's just a matter of installing the right upgrades.
Old May 30, 2008 | 11:35 AM
dutchlincoln79
okay.
So, when i buy a E4OD for $1000 from a tranny shop on which bill states that it has received all upgrades of the '96 and later tranny, i'll be safe?
How can one check these things?
Old May 30, 2008 | 12:10 PM
greystreak92
Suit yourselves gentlemen. There is a reason that Ford completely reworked the E4OD after 1990 to the point that the casing cannot even be reused from a 1990 unit. There is also a reason most transmission experts won't touch 'em with a ten foot pole and IF they do they cut the warranty in half or won't warrant the reman. Yes, Ford put them behind every engine under the sun. Doesn't mean they would LAST there. Diesels eat them on a regular basis. The previous was NOT a rant and I don't appreciate the accusation. I've dealt with the E4OD in just about every application it was dropped in. Including a few stand-alone custom swaps like the one suggested here. I have done. Argue the point as you see fit.
Old May 30, 2008 | 12:20 PM
dutchlincoln79
Well, in no way i intend to trash you, but i just purchased a "project" from someone which includes a 460EFI and a E4OD, and i have the bills with them; he payd $1000 for it.
Thats why i asked...
It is a '91 engine, and a ditto trans with upgraded-to-'96-specs on the bill. The request for that specific year was done to have it equipped with the mechanical speedo output to fit the car it comes into...
Old May 30, 2008 | 01:12 PM
jas88's Avatar
jas88
There is a reason that Ford completely reworked the E4OD after 1990...
That's not much of an argument. The E4OD trans debuted in 1989, so your complaint is the first 2 years were no good but the remaining 18 years of a 20-model-year run are OK? I don't get you. My trans is a '91 and would be considered an "early" model given that Ford *still* uses this trans today, yet you contend "well you got one of the good ones" after Ford reworked the case. I don't see how this makes your argument for you.
Look, some folks can break an anvil with a rubber hammer, but I am betting there are more E4OD/4R100s out there with >100K miles on them than there are ones with <100K that are broken. Plus I don't know who you are having do your trans work, it may be that half the problem here is guys rebuilding the E4OD that don't know what they are doing. It's no different than people complaining how their TTB/TIB always eats tires - it's the guy doing the alignment that is the problem.
Old May 30, 2008 | 02:55 PM
Conanski's Avatar
Conanski
Guys, a rebuilt tranny from Joe Blows tranny shop is NOT a "built tranny", it's just a case filled with "stock spec" parts from the cheapest offshore supplier Joe could find. The fact this only lasts 40k-60k should not be a surprise to anybody. The web is littered with all the info you could ever need on upgrading a tranny to handle abuse, just do a search.
80demoace
Jul 14, 2008 04:26 PM
THE KING
Jan 7, 2008 08:43 AM
gruvy01
Jan 1, 2005 12:11 PM
cardiacjohn
Nov 19, 2002 01:01 AM
