Parking Brake Question
Old Nov 14, 2013 | 10:45 PM
HydroDog's Avatar
HydroDog
Rehabbing a 1965 F100. At the lever under the bed where the cable from the cab with the round ball; does the round ball go into the slot in the arm that the rear brake cables attach or does something attach to the cable that fits the slot on the lever better?
Old Nov 15, 2013 | 08:49 AM
Bill W's Avatar
Bill W
Originally Posted by HydroDog
Rehabbing a 1965 F100. At the lever under the bed where the cable from the cab with the round ball; does the round ball go into the slot in the arm that the rear brake cables attach?
Correct, the ball fits into the notch on the equalizer bar.
Old Nov 15, 2013 | 11:13 AM
Jason Ellison's Avatar
Jason Ellison
Do you have a pull handle for your e-brakes under the ignition? I have a 66 with one, and it doesn't even com close to working. Didn't know if that was the factory setup or not.
Old Nov 15, 2013 | 12:15 PM
Bill W's Avatar
Bill W
all 61-66 F series trucks have a pull handle under the dash, left of the steering wheel.
Jason, does you handle pull out almost all the way? if so, your back brakkes need adjusting or the cables under the truck can be adjusted.
Old Nov 15, 2013 | 12:40 PM
Jason Ellison
It pulls out all the way. I wonder if the cables are even there to be honest with you. Thanks for the info.
Old Nov 15, 2013 | 02:23 PM
Conserv's Avatar
Conserv
Or at least most: there are a few that came from the factory with center-hump-mounted levers that actuated parking brakes on the driveshaft just behind the transmission. These may be largely (all?) F series above the F-350 level but I believe I've seen an F-350 with a factory 4-speed and this arrangement (transplanted from a larger truck?).
Others here are better qualified to comment on these floor-mounted lever-actuated driveshaft parking brakes. I believe that F-350s uniformly came with driveshaft handbrakes and I recognize that many, such as my '61 F-350 with a 3-on-the-tree manual transmission, indeed, came with the under-dash pull handle.
Steve
Old Nov 15, 2013 | 06:36 PM
HydroDog's Avatar
HydroDog
Thank You Bill
Old Nov 16, 2013 | 08:17 AM
CropDusterMan's Avatar
CropDusterMan
These parking brakes were pretty notorious for working like crap...I completely rebuilt my rear drums (new parts),
had new e-brake cables and housings, serviced the handle and the brake lever engages the brakes as it should,
problem is that it is just not an efficient design.
Old Nov 17, 2013 | 05:04 PM
shano63's Avatar
shano63
I'm doing this as well. I need to get my truck ready for NYS inspection, I miss CT...lol. Parking brake doesn't work. I adjusted the cables, still nothing. Took the rear drums off and saw the cables coming through the drum but there was nothing for the cable to attach to. Missing everything in both drums...
Old Nov 17, 2013 | 06:49 PM
camperspecial65's Avatar
camperspecial65
Its a pretty easy part to find in wrecking yards ..same part used on 63-66 Thunderbird, 70-71 big car Ford w/ 11x 2 1/2''brakes, 66-75 Bronco w/ 11x 1 3/4" brakes as well as 64-67 F100 trucks
This is the parking brake lever..attaches to the cable inside the drum and the brake shoe and is held on the brake shoe by a horse shoe shaped clip which can be obtained locally at the parts store.
- cs65
Old Nov 17, 2013 | 07:00 PM
shano63's Avatar
shano63
Awesome, thanks for the post. I'll start snooping around....
Old Nov 18, 2013 | 12:04 AM
HydroDog's Avatar
HydroDog
Along with the lever arm, you will need the link bar and spring.
Old Nov 18, 2013 | 09:16 PM
shano63's Avatar
shano63
Thanks Hydro, I think I found everything at Jeffs Bronco Graveyard... 1966-77 Early Bronco - Park Brake - Hardware & Parts Sorry to hijack you..
Necco-2
17
Dec 2, 2019 04:06 PM
filthy6
Dec 9, 2017 09:02 AM
Rusty 57
Sep 8, 2016 09:25 PM
gangstakr
Jun 25, 2006 09:30 AM
