Convert 4x2 van into 4x4 van
Old Nov 6, 2013 | 04:03 AM
moosey78's Avatar
moosey78
Title pretty much says it all. Got a 99 E350 V10 powered extended length 2wd van that I want to make 4x4. I know I gotta change the rear end out to a newer ford truck rear end so I can keep the rims the same bolt pattern all the way around. I just wanna know what all it will take. I know I need the front axle and suspension and the T-case off of a F350. Am I missing anything?
Old Nov 6, 2013 | 08:49 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You need to disassemble the transmission to change the output shaft to a 4x4 shaft.
Old Nov 6, 2013 | 08:54 AM
JWA's Avatar
JWA
If this turns into an actual project please post some photos of your progress---I'm sure many of us here would enjoy going along for the ride with you!
Old Nov 6, 2013 | 07:12 PM
Shocker's Avatar
Shocker
There is tons of information out there on this.
Check out 4x4 Van Conversion kits. There is lots of info there and they have kits for DIY.
If I am not mistaken, the 99 has the 8x170 bolt pattern, so you could use a 99+ Super Duty Dana 60. Pretty easy to find and reasonable as well.
As Mark said, you will need to change the transmission or shaft out for the 4x4 version. Plus need to find a transfer case. Probably the Borg Warner 1356.
Old Nov 7, 2013 | 12:21 AM
moosey78's Avatar
moosey78
The econoline vans use the old bolt pattern 8x6.5 and I was probably just gonna change the whole trans out
Old Nov 7, 2013 | 12:31 AM
Shocker's Avatar
Shocker
Touche'!
Well, instead of swapping the rear axle housing, what about just getting a pre 99 Dana 60?
Car-part.com shows quite a few around for under 1000 complete.
Old Nov 7, 2013 | 01:47 AM
moosey78's Avatar
moosey78
The pre dana 60s use the 8x6.5 pattern too lol. Ford changed the F series truck pattern around 95 or 97. The F series uses the 8x170 bolt pattern. I'd have to get a pre 95 front end or a post 95 rear lol.
Old Nov 7, 2013 | 02:10 AM
Shocker's Avatar
Shocker
Well, it seems like you have all be bases covered then. Now get the transfer case and get to work!
Old Nov 7, 2013 | 07:15 PM
Rick1025's Avatar
Rick1025
There are adapters available to switch from the newer f series bolt pattern to the van pattern. Also the track witghs are different.C ontact Ujoint offroad for conversion.There is much more to this than meets the eye. my 2002 Quigley uses a dana 60 front axle from a mid 70's GMC 30 series.It gets away from the high pinion Ford dif and gets more frame clearance. Also, the gas tank needs to be shortened for the transfer case,It may be quite a bit cheaper/easier to get a used van; check E-Bay Ford van 4wd. There are usually a few for sale.
Walden
Feb 18, 2017 06:56 PM
curtis73
Jan 21, 2012 01:04 PM
Dr.B
Jan 30, 2010 02:32 PM
Rulebreaker
48
Jan 29, 2009 02:33 AM
cyerger57
Dec 8, 2005 07:31 AM
