How to remove locking gas cap?
Old Nov 5, 2013 | 12:22 AM
DieHardChief's Avatar
DieHardChief
Lightbulb How to remove locking gas cap?
Whats the best way to remove a locking gas cap, I bought 2 new ones to install and didnt realize the rear tank has one on there but I know the key for that cap didn't come with the truck when I bought it, I'll def have to check around in the nuts/bolts pile though, just in case...
Anyway whats the best way to get it off without damaging anything.
Thanks.
Old Nov 5, 2013 | 03:04 AM
co425's Avatar
co425
Take her to a competent lock smith. Should be able to make you a key for around $20.00.
Old Nov 5, 2013 | 06:57 AM
rogue40's Avatar
rogue40
The key is probably in the ashtray.
Old Nov 5, 2013 | 07:58 AM
Wbruiser2's Avatar
Wbruiser2
If it's plastic, you can pry the cover off and then pop the cylinder out. The plastic types only keep honest people honest. If it's metal, I don't know..
Old Nov 5, 2013 | 09:02 AM
84espy's Avatar
84espy
I have punched through a metal cap with a straight screwdriver and used that as a key before
Old Nov 5, 2013 | 09:08 AM
rogue40's Avatar
rogue40
If the key isn't in the ashtray then you may be able to get to the lock tabs from underneath. I don't know if you can see in there well enough to do this but I'd try anyway.
Pull the rubber filler neck hose from the filler tube. With a long screwdriver reach up into the filler tube and release the locking tabs. It might help to have someone pull the cap out as you do this.
I might also be possible to remove the filler neck from the bed to get at the back side of the cap.
Old Nov 5, 2013 | 09:41 AM
fmc400's Avatar
fmc400
MSEE
I've had two new-to-me vehicles come with a locking gas cap sans key, and in both cases it popped right off with a screwdriver.
Old Nov 5, 2013 | 01:04 PM
jas88's Avatar
jas88
Yep, a big screwdriver liberated the one on my '74 F350 tow truck, after which I found the key in the ashtray...
Old Nov 5, 2013 | 05:22 PM
V10man's Avatar
V10man
The tread from a 10ply Michelin radial took mine out at about 65mph! Also took out the side of the fender and bent the bed floor.
Old Nov 5, 2013 | 10:41 PM
wdfp's Avatar
wdfp
I have used a half inch drill bit and drilled into the lock a little bit then used a screwdriver to turn it and it come right off..
darmento
Apr 9, 2018 12:50 AM
moconnor603
15
Nov 26, 2016 09:25 AM
flhinj
Mar 28, 2007 08:17 PM
wesh
Oct 31, 2006 08:07 PM
Ferrite
Jun 12, 2002 09:12 PM
