long crank
Old Nov 4, 2013 | 09:05 PM
BLADE35's Avatar
BLADE35
Originally Posted by Bullitt390
You don't have to remove the oil rails to change the DP's and SP's Benny
Josh
Oh Chit your right
Well that would be great if that rail stayed put
Ya know I was thinking about welding those plugs Holes
But it kinda kills it or Commits to one side only
Old Nov 4, 2013 | 09:10 PM
big inch's Avatar
big inch
Have you driven it since replacing the dp's and sp's?
Old Nov 5, 2013 | 05:38 PM
bubblechaser's Avatar
bubblechaser
Ok I took it for a drive to warm it up. When I started it it took 3 seconds to start. So warm at 2500 rpm my ICP is 1400 and my IPR is 40. It did run a little ruff when it first started but that is the quickest it has started in a long time. I have OEM filters and OEM caps. I have been running 15w40 but I have been thinking about going to 10w30.
Old Nov 12, 2013 | 05:12 PM
bubblechaser
The truck is starting and running great. I guess I should have run it more to get the air out of the system. Which is pretty bad considering I am a hydraulic mechanic. sorry it took so long to post my results it has been very busy lately. thanks for every ones help.
Old Nov 12, 2013 | 05:29 PM
BLADE35's Avatar
BLADE35
Thanks for posting outcome!!!!!!
Ford recommends a Few "SPIRITED RUNS" to purge air
No Biggie
Its Common here is a thread from yesterday
https://www.ford-trucks.com/forums/1...-no-start.html
Old Nov 13, 2013 | 08:39 AM
droff85's Avatar
droff85
Ok not trying to highjack but i am having a similar problem. I own a small business and just bought a new shop truck. 07 250 with 56000 some odd thousand miles on it. Found it at a local camper dealer. They said the previous owners used it to pull a 5th wheel camper and decided to buy a motor home so they traded the truck and camper in together.
I have been driving the truck daily for a couple of weeks now and have noticed that every once in a while it would take several seconds to start. I figured it was fuel filter problems so I changed them. It started great for a few days then started the long start problem again. Yesterday I drove about 20 miles and shut it off when I arrived but had to move immediately after I got there and it took 3 almost 10 seconds crank sessions to get it to crank.
Any ideas? I don't have a scanner to look at what sensors are doing so any other advice would be very helpful.
Old Nov 13, 2013 | 09:02 AM
npccpartsman's Avatar
npccpartsman
You need to get the truck code scanned and you need to get something to monitor what the truck's really doing through the OBDII port. ScanGaugeII, Dash Boss, Edge Insight are all good options. Most parts stores will code scan the truck for free. If I had to guess I'd say you were suffering from a high pressure oil leak but that's strictly a guess. There's no way to be intelligent without having some kind of data.
Old Nov 13, 2013 | 09:05 AM
bubblechaser
I also had that problem. It ended up being my ficm and battery's. You need to check your volts and ficm volts koeo and cranking. They should not drop below 45. When mine went bad I was dropping to 42 when cranking. Hot or cold it was taking a long time to start.
Old Nov 13, 2013 | 09:12 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
As a side point, I find it funny whenever a diesel doesn't start right the fuel filters are the first to be blamed.
This isn't the 1950s...
In 35 years of life I have only encountered one diesel that had plugged fuel filters, and that was a Deere 762B that had sand and dirt thrown in the tank by vandals.
Josh
Old Nov 13, 2013 | 09:16 AM
Money-Pit's Avatar
Money-Pit
My helpful advice would be...get a scanner so you can see what your sensors are doing.
Think of it this way....when we go to the hospital because out heart isn't ticking right, the medical staff use "monitors" to see what our body is doing. Depending on what their monitor tells them, they come up with a solution to your problem. The 6.0 is an engine that needs a monitor (scangauge, dashboss, torque, etc) to see what is going on in order to diagnose the problem. Once it is diagnosed, there are many 6.0 Dr's here that will come up with the the solution!
(I know that's a weird translation.....)
Carolina Rig
Nov 1, 2018 08:49 PM
fordf150guy
Dec 21, 2016 06:31 AM
rwallen85
Nov 26, 2015 02:47 PM
Donzi Dude
Aug 6, 2013 06:08 PM
dusred
Dec 1, 2009 05:27 PM
