long crank
Old Nov 3, 2013 | 07:01 PM
bubblechaser's Avatar
bubblechaser
long crank
So I was having problems with a long crank when cold. I thought I had it narrowed down to dummy plugs. I changed the dummy plugs and stand pipes and now it seems to have even longer starts. I lubed the O-rings before I installed. I unplugged the ICP and it starts right up. The truck is a 06 F250 4x4 CC SRW with 103K. I guess my question is what could I have done when I did the work or could it be the ICP sensor. When I crank the ICP reads 137 when it starts. My scan gauge is set at fast. I have sycn on ficm and cam/crank. Also when I stop and then try to start it back up it still takes a long time to start. Thanks for any help.
Old Nov 3, 2013 | 08:18 PM
78fordman's Avatar
78fordman
What is the IPR% and ICP at idle once it starts?
Old Nov 3, 2013 | 08:20 PM
BLADE35's Avatar
BLADE35
and ICPV at KOEO
Old Nov 3, 2013 | 08:25 PM
bubblechaser
ICP is 550 when warm and IPR is 22% ICP is 0.2 at KOEO
Old Nov 3, 2013 | 08:30 PM
BLADE35's Avatar
BLADE35
Looks like the ICP sensor is OK
Post ICP and IPR% at High Idle (2500rpm)
Old Nov 3, 2013 | 08:38 PM
bubblechaser
I will post tomorrow. Is there something I could have done. Could I have cut an o-ring
Old Nov 3, 2013 | 08:41 PM
BLADE35's Avatar
BLADE35
Done or Missed
How was the Nipple cups those are starting to fail more often Now
did any cups spin freely
Old Nov 3, 2013 | 08:45 PM
bubblechaser
Not sure what you mean
Old Nov 3, 2013 | 08:46 PM
BLADE35's Avatar
BLADE35
the little nipple cups on the Oil Rails that go into the injector tops
Old Nov 3, 2013 | 08:52 PM
bubblechaser
I didn't check. I just changed the stand pipes and dummy plugs. I guess I will take it back apart if I have to.
Old Nov 3, 2013 | 08:57 PM
BLADE35's Avatar
BLADE35
Don't take apart Yet do some testing
Old Nov 4, 2013 | 07:35 PM
bubblechaser
Ok so I did some measurements. KOEO ICP 3 ICPV.23 IPR 14.4 Cranking ICP 170 When it started ICPV 1.8 IPR 77 RPM 550 it toke 8 seconds to start. Cold idle ICP 1134 ICPV 1.32 IPR 32 Idle 744. Warm RPM 2500 ICP 1600 ICPV 1.8 IPR 44 Warm Idle ICP 581 ICPV .8 IPR 22. After it was warm I turned it off and restarted it and it took 3 seconds to start.
Old Nov 4, 2013 | 08:12 PM
BLADE35's Avatar
BLADE35
So the ICP sensor Looks OK
Looks like a Leaker Your IPR is 4% making Up for Lost Oil at High Idle WAS EOT at 185*F at Test??
DO you feel Like a Oil Rail Nipple Killed an Inject oring or something?? Did the rail seam hard to line up
I think you Keep it Together and AIR TEST IT!!!!COLD
Got the right oil fil;ter assbly
<table width="691" dir="LTR" border="1" cellspacing="0" cellpadding="7"><tbody><tr><td width="17%" height="3" valign="TOP"> IPR #
</td><td width="17%" height="3" valign="TOP">Injection Pressure Regulator
</td><td width="17%" height="3" valign="TOP">14.84
</td><td width="17%" height="3" valign="TOP">24
</td><td width="17%" height="3" valign="TOP">40.60
</td><td width="17%" height="3" valign="TOP">0 - 50
</td></tr></tbody></table>
<table width="698" dir="LTR" border="1" cellspacing="0" cellpadding="7"><tbody><tr><td width="17%" height="3" valign="TOP"> ICP
</td><td width="17%" height="3" valign="TOP">Injection Control Pressure
</td><td width="17%" height="3" valign="TOP">0.2
</td><td width="17%" height="3" valign="TOP">1.0
</td><td width="17%" height="3" valign="TOP">1.8
</td><td width="17%" height="3" valign="TOP">0.15 - 4.7
Old Nov 4, 2013 | 08:25 PM
BLADE35's Avatar
BLADE35
What RPM does it crank at??
Old Nov 4, 2013 | 08:36 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You don't have to remove the oil rails to change the DP's and SP's Benny
Josh
