I'm an IDIOT! Now I need a Ford PN.
Was changing orings on the HPO line fittings that go into the HPOP today. Apparently I got a little over zealous cleaning everything with the compressed air, cause those 2 little springs sticking out of the HPOP disappeared. I fished around and found 1, but after 45 minutes, couldn't find the other. None of the ford dealers can find it in the schematic, and quite honestly, don't seem to want to be bothered. Please help me out, I need this truck running ASAP!
That would be great! I hope your right on that. Thanks! Also, do you know the answer to this question; is the non-serviceable plug the one behind/next to the 2 HPO fittings on the HPOP? The kit I got had 3 o rings and one was for that end plug. From reading on here I know the non serviceable plug can be serviced, so was wondering if I'm eliminating that one inadvertently. That sucker doesn't want to stop dropping though... Maybe overnight it will stop.
You don't need those check valve springs....delete them both and you will be fine. I think those were a left over item from back when the front cover reservoir was plumbed differently (before the anti-drain back stand pipes were added...)
The non-serviceable plug is on the bottom of the pump.
Just for future reference if anyone comes across this later. I reassembled without the springs and it seems to run exactly the same as before. I was a little worried about the long cranking starts at first, but it seems to be a result of a drained HPOP, and is slowly getting better as the air drains out of the system. Thanks again for the input guys!
Fat_Batster
54
01-05-2016 05:43 PM
outdoormaniac
24
05-14-2010 03:03 AM
