Started the tranny flush project today. While I'm changing the filter, I'm going to access the feed bolts to check to see if they are loose and I can re-torque them. Have an issue of 'tranny is engaging first gear slowly'.
I'm at a point that I need to ask some questions. I'm just a DIYer hobbyist, so, I don't know a lot of the terminology and I'm hoping I can get some guidance through this process.
I removed the pan, the filter, and I'm going for the valve body. So I removed this part. Valve body? or, one part of the valve body?
I'm guessing I have to remove the plate that was under this part to get to the feed bolts, but this plate (#1) is underneath other parts.
Do I remove parts #2, 3 and 4 to get that plate?
Any info is appreciated.
Thanks,
Rich
Reason: pictures disappeared
