Name that part!
Old Oct 30, 2013 | 03:50 PM
toothpix's Avatar
toothpix
Name that part!
So the hardest part about learning how to work on my truck has been figuring out what in the heck I'm looking at so I can go online and research it. I was under my truck to work on my speedo cable and I noticed a small hole in a cover but I don’t know what its called. The cover is directly behind the oil pan and underneath the motor and tranny it think. What is it called? My truck is a 75 f100 4x4 with at 390 if that helps. I'll try to get pictures as soon as I can.
Also what is the name of the part inside the transmission that drives the speedo cable. I'm not talking about the gear that connects directly to the speedo cable but the one that drives that gear. How hard is that to replace? Should I give it a shot or take it to a transmission person?
Thanks for the help!
Old Oct 30, 2013 | 04:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Well, the second one is the speedometer drive gear. How difficult it is to replace depends on the transmission you have, on a C6 the gear is not replaceable. Its part of the output shaft.
On the first question, your description is too vague. Are you talking about the inspection cover? Do you see the backside of the flywheel/flexplate through it? A picture is worth a thousand words.
Old Oct 30, 2013 | 04:21 PM
toothpix's Avatar
toothpix
So how do I tell what kind of tranny I have, its not original to the truck so the vin is now help. Its a 4 speed manual if that helps.
Old Oct 30, 2013 | 04:32 PM
hickory1991's Avatar
hickory1991
You may be talking about the inspection cover on the bell housing if it is a 4 spd. The little hole is a drain hole in the cover. Pictures would help.
Old Oct 30, 2013 | 05:01 PM
toothpix's Avatar
toothpix
I'll get a picture up might be friday morning before I can get to it.
Old Oct 30, 2013 | 05:46 PM
HIO Silver's Avatar
HIO Silver
Pick one.
Manual Trans:
auto trans;
Old Oct 30, 2013 | 05:57 PM
toothpix's Avatar
toothpix
Mine is manual, and that is exactly what I was talking about, so I dont need to worry about that hole?
Old Oct 30, 2013 | 06:18 PM
HIO Silver's Avatar
HIO Silver
It's called an "inspection cover"
Nope... nothing except to make sure the drain hole is not obstructed.
Shiveron
Sep 30, 2014 06:44 AM
4601ton
Jan 5, 2012 07:46 PM
ssj7kids
Jul 5, 2011 11:23 AM
cwdegood
May 3, 2007 06:07 PM
rkreed
Nov 12, 2005 04:15 PM
