Removing speedometer driven gear NP435
Old Nov 12, 2005 | 03:11 PM
rkreed's Avatar
rkreed
Question Removing speedometer driven gear NP435
I am trying to remove the speedometer gear from the side of my transmission. I can't a clamp bolt or snap ring. It does not seem to screw in. This is in a 1975 F600. Thanks
Old Nov 12, 2005 | 03:15 PM
ford390gashog's Avatar
ford390gashog
is yours the electric sender type? you may have to pull the top cover off to get to it.
Old Nov 12, 2005 | 03:45 PM
rkreed's Avatar
rkreed
speedo
No it is the cable type mechanical speedometer. I can tell that it is a separate part. I can't understand what is holding it in the tranny. Thanks
Old Nov 12, 2005 | 04:15 PM
rkreed's Avatar
rkreed
Solved
A closer look and I found that I needed to use an allen wrench inside where the cable goes.
kr514
Sep 24, 2015 10:22 AM
MIKES 68 F100
Jul 29, 2015 04:51 AM
Stevenbowman23
Mar 23, 2015 12:12 AM
JacobRM
19
Jun 3, 2014 06:35 PM
