I don't know about being too low. They are close to the tire. You would have to have the top of the tire sticking up out of the top of the bed to get the bottom of the tire higher than the bottom of the pipe. If it were near the middle of the truck I would be worried. It looks like they drop down at the point where they go out.
Wish I could have one of those engine and trans in my f1... The hater's could hate me all they want. LOL....
Your doing great work... Coating the pipes one you finish would keep them looking as good as they are now, but add the finishing touch to them. and will also help keeping the heat away from the other components.
Hi Moe,
Thank you kindly. I would have done a Coyote motor if I could justify the $ difference.
We'll see if I can wrangle another $450 to $550 from my piggybank for the exhaust coating. Agree with you. I have a lot of hours in it already, so finishing it off properly makes sense. And keeping the heat in will be a great benefit!
I bought some AL tubing (including 180 degree bends) to make some heat shields, but with the ceramic coating, I think that wouldn't be necessary.
I think you're going to love the conversion. Before I started on my current project (49 F1) I placed a 4.6L mod engine from a '06 Mustang along with the 5R55S trans into my 49 Ford Convertible. I used the original wiring harness and had to sort through it to figure out what I needed and didn't and how to marry it to the 49 wiring harness. One big issue was figuring out how to bypass the antitheft system, and I had to cut and reweld the X-frame to make the trans tunnel a bit bigger--but now I have a solid motor that get me 22 MPG on the highway--and made the trip from Houston to Chicago then all of Rt 66 to California and back home without a problem.
A few pics:
Doug,
Is that a picture of a Glide Engineering seat in the picture? It sure looks like one to me.
Philip
Hi Philip,
Good eye - having looked at Glide's website, I think you are right. I saw the photo when looking at examples for my truck seat and liked it.
The upholstering job and leather is what I like most. I will not have an armrest.
Nice job on the truck! <p>As far as exhaust I am on the cheap side, I spray them with black enamel spray paint and it works great to keep them from getting rusty and looks decent too. Pipes dont get hot enough to even blister the paint.
Hey Dave,
Thanks for the info! Maybe I will rethink the ceramic coating. I did use VHT's Flame Proof rattle can product on a set of manifolds. It worked well when I followed the directions to cure the paint. I used my gas BBQ grill.
The aluminized steel should keep it nice (where I didn't weld).
Maybe I'll see if VHT sells a clear where I could just clean up the welds a bit and then use that product? We shall see.
My budget seems to be stretched, but I'm happy with how things are turning out.
Nice job on the truck! As far as exhaust I am on the cheap side, I spray them with black enamel spray paint and it works great to keep them from getting rusty and looks decent too. Pipes dont get hot enough to even blister the paint.
That is my route as well. These things don't see salt, and that is what kills everything around here.
got the other steering shaft support fitted up and tacked in. Had to drill an elliptical hole and modify the shape of its flange since I wasn't installing it square to the frame.
