late model electronically controlled drivetrain install
Old Nov 2, 2013 | 12:53 PM
  #31
DW SD's Avatar
DW SD
One more shot of the crossover.
Old Nov 2, 2013 | 05:53 PM
  #32
oldmerc's Avatar
oldmerc
oldmerc
Nice fab work . Did you do all that exhaust work .
Old Nov 2, 2013 | 06:01 PM
  #33
DW SD's Avatar
DW SD
Yes. Slowly
A few hours a week.
Thank you!
Old Nov 3, 2013 | 08:18 AM
  #34
oldmerc's Avatar
oldmerc
oldmerc
No need to rush , it's supposed to be fun . For me its therapy .
Old Nov 3, 2013 | 09:55 AM
  #35
DW SD's Avatar
DW SD
Therapy for me too. But, I'm eager to drive it. And always fun to see your own vision come to reality.
thanks,
Doug
Old Nov 4, 2013 | 01:56 PM
  #36
DW SD's Avatar
DW SD
got the steering shaft mocked up last night - using 3/4" oak dowel.
Old Nov 4, 2013 | 03:02 PM
  #37
DW SD's Avatar
DW SD
Will have to turn down the shoulder in a lathe to get the steering shaft support Heim closer to the frame. There will be about 1/4" of shoulder and the jam nut when installed.
Here's a photo of it though.
Doug
Old Nov 12, 2013 | 10:03 PM
  #38
DW SD's Avatar
DW SD
Finished off the fan shroud. Plasma cutter did a good job of cutting the big hole..
Old Nov 12, 2013 | 10:04 PM
  #39
DW SD's Avatar
DW SD
Before the hole...
Old Nov 12, 2013 | 10:06 PM
  #40
DW SD's Avatar
DW SD
Finished off the exhaust, except a bit of final welding.
You can see the in series fuel pumps. They are Bosch and come from a Mercedes Benz. I had them as spares from my 1992 500E. They connect to the corvette filter / regulator and from there to a hard stainless fuel line towards the engine. They are mounted on vibration isolators on a bracket I built.
The 9" has a locker of some flavor.
Old Nov 12, 2013 | 10:09 PM
  #41
DW SD's Avatar
DW SD
Tips are double wall stainless from flow master. 2 1/2" to 4".
I decided not to go over the rear end as I'm thinking I will one day install an IRS from a thunderbird or Mark VIII.
DOUG
Old Nov 12, 2013 | 10:11 PM
  #42
DW SD's Avatar
DW SD
Apologize for all of the posts. My iPad only allows one photo per reply. If I add an extra file, the web app replaces the precious file. Uggghh
Here is the driver's side outlet. They are very symmetrical. From above the tips loosely follow the swelling curve of the fender.
Note the scale makes things look rather funky in the photo. In reality it matches the passengers side really well.
Old Nov 12, 2013 | 10:15 PM
  #43
DW SD's Avatar
DW SD
Debating if I will ceramic coat these pipes and manifolds. Kind of pricey. Still lots of labor went in to them and I'd like to protect.
Anyone know a reasonable vendor near San Diego that won't want a arm and a leg to coat?
In looking back I should have used stainless. Initially the extra dollars over aluminized steel seemed more than I wanted to spend.
Would have been good for my TIG skills too
Doug
Old Nov 12, 2013 | 10:18 PM
  #44
DW SD's Avatar
DW SD
I will make some heat shields for the rear fenders from 1/8" aluminum that I used to make the fan shroud to protect the fenders from heat.
Old Nov 13, 2013 | 01:00 AM
  #45
ohbrian's Avatar
ohbrian
Those exhaust pipes look REALLY low.
