Getting a mini starter, thoughts?
Old Sep 8, 2013 | 04:31 PM
wyckedcombo17's Avatar
wyckedcombo17
Hey all,
I have a '78 4x4 with a 4 speed and a 400 that isn't stock. (180 tooth fly)
The napa starters cant handle the heat or the higher compression of this new engine. I'm on my second one in 3 months.
So what are your thoughts on mini starters? I'm looking at this one right now
RobbMc Performance Products - Ford BB Starter
Any other suggestions?
Old Sep 10, 2013 | 10:51 AM
7Ford6's Avatar
7Ford6
I did it over 10 years ago on my 390 with headers and still going strong... Was having the same problem as you are,, got tired of swapping em out...
Old Sep 10, 2013 | 11:31 AM
hasteranger's Avatar
hasteranger
people say a heat shield or insulation can make a difference. No experience personally.
Old Sep 10, 2013 | 11:47 AM
7Ford6's Avatar
7Ford6
lol,, i had done that to the oem starter,,, Just didn't work,,, to close to the pipe... simpily transfered it over to the mini tho just in case...
Old Sep 10, 2013 | 12:19 PM
psychlopath's Avatar
psychlopath
Just buy a starter for a 95 F250 with a 460. It's permanent magnet and gear reduction. I'm pretty sure they are cheaper than the aftermarket unit. Is check rockauto, but it doesn't play with my phone. Keep your stock starter relay in the picture; just look up the pmgr starter wiring thread.
Old Sep 10, 2013 | 01:58 PM
Bigbruce's Avatar
Bigbruce
I went with the mini starter on my used a power master from summit
Old Sep 10, 2013 | 03:18 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
NAPA=
Need
Another
Part
Already
Old Sep 10, 2013 | 04:46 PM
fmc400's Avatar
fmc400
MSEE
PMGR starters are by far superior; I run one on my 300 because it allows me to change it out while keeping the header on. Just be sure to wire it properly, and carefully route and protect the heavy-gauge hot-at-all-times cable that must run down to the starter - especially if exhaust is nearby.
chiefsfootball
20
Dec 16, 2015 10:35 AM
Corkwheats
Aug 8, 2015 10:09 PM
dogsniper
Feb 18, 2008 10:21 PM
iridium
13
Aug 14, 2007 03:28 PM
charles jones
38
Sep 21, 2005 09:23 PM
