MILLER OBSOLETE PARTS in Binghamton NY has ONE = 607-722-5371.
CARPENTER NOSOBSOLETE PARTS in Concord NC has ONE = 800-476-9653.
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
1) C1PZ-2853-A .. Replacement Front Cable / Obsolete
CARPENTER has FOUR.
GREEN SALES CO. in Cincinnati OH has ELEVEN = 800-543-4979.
well not sure, i looked up the 2a753 number that supercedes and it is for the 1966 bronco. problem is it says that it is 60" overall. In the ford parts list above it shows the original at 64 3/8" which is what mine is. I will continue working on this. Thanks all for the help!
I looked for cables for a month or more gave up I found a California push pull in Chico they make cables for trucks and tractors they can match what you have
Not cheap but I have a working e-brake or call around to the nos outfits good luck
thanks, it looks like I might have to go that route. The prior owner must have not needed the park brake, because there was only one broken rear cable left. they also pulled the lever and spreader bar out of both rear drums. i have alot of parts to find if i want a working park brake. it is a 4 speed manual so i would like to have one!
Ok, Thanks for the clarification. I guess they know that the shorter cable will work, as long as you replace the front cable also. The cable must go from the drum assembly to the parking brake cable bracket, I just wasn't sure that the bracket could adjust 4" to accommodate the shorter cables. Thanks!
All three cables are adjusted at the same location.
2853 front cable attaches to 2A605 lever. 2628 threaded adjustment rod attaches to lever and to 2A605 equalizer, where it is double nutted in place.
