1978 - 1996 Big Bronco
Power window issue
Old Sep 3, 2013 | 05:38 PM
justgunner's Avatar
justgunner
Question Power window issue
My drivers window has just stopped working,. When I work the switch I hear the motor clicking, the passenger window and rear work fine. It just went up the other day and never moved again,. I took apart the switch cleaned the contacts and greased them . There is power to the switch. So is it just stuck? Do motors go that fast? Anybody have a fix?
Old Sep 3, 2013 | 06:25 PM
Black Ford XLT's Avatar
Black Ford XLT
Just gunner, common problem for our broncos The motor is running because the plastic gear the motor pushes has disintegrated (heat , use of window, pass. especially).You can replace the motor /regulator or rebuild the one you have. If you decide to rebuild , auto zone, advance have the replacement parts. I have rebuilt my 3 regulators a few times .Good luck TR
Old Sep 3, 2013 | 06:32 PM
justgunner's Avatar
justgunner
Window
Well it clicks at the motor but I don't hear it running. Like if its a slipped would it not wine like its running but not moving just wondering 'cause if I knew I would not be asking,. Is it fused seperate from the passenger side?
Old Sep 3, 2013 | 10:14 PM
Encho's Avatar
Encho
The Southernmost Mod
Open the fuse cover and check the sticker, but I think they go through the same fuse.
pounder90
1997 - 2003 F150
Jul 17, 2017 11:03 AM
r0lex
21
Feb 23, 2016 12:15 AM
tyler9mm
2004 - 2008 F150
Aug 1, 2007 03:11 AM
dizzead
1997 - 2003 F150
Aug 24, 2006 12:22 PM
jason86
Feb 8, 2005 02:58 PM
