Sponsored by: Auxito
Power window problem
Old Aug 20, 2006 | 04:28 PM
dizzead's Avatar
dizzead
Here's the deal....
My passenger window will go down, but not up. The window is completely down in the door.
I went thru the hassel of removing the window motor; the gear spins ONE way ( to roll the window down). I thought the motor was bunk, so I bought a new one. The new one does the same thing....spins one way, not the other. So, I assume the problem isnt the motor.
Considering I can get the motor to spin, with both the driver and passenger side controls, down, but not up, Im assuming its not the switches.
I literally pulled each and every fuse, under the dash, and under the hood, and theyre all good. So, that eliminates that theory too.
I obviouly have a short somewhere. Theres juice going to the motor, no doubt about it, it just seems strange that the motor will only turn one way... and like I said, I purchased a new one and it did the same thing?!?!?!
Perhaps there's a current polarity issue? I have no clue.
Id appreciate any suggestions.
Old Aug 20, 2006 | 06:03 PM
BowTieHatr's Avatar
BowTieHatr
trace power and ground through the switches. one or both could be bad.
Old Aug 20, 2006 | 11:18 PM
Racerguy's Avatar
Racerguy
Welcome to the forum dizzead
If the passenger's side switch is dead then the window won't work from either side.
The power and ground signals from both switches go through the passenger's side switch to the passenger's side motor.
Old Aug 21, 2006 | 07:53 AM
4fords's Avatar
4fords
Racerguy,
Are you sure about the grounding? My manual shows both windows are grounded through the driver (left door) switch. I had the same problem and ended up changing the driver door switch. Worked good for a while the started giving my problems again. I cleaned both connections with some electrical contact cleaner and haven't had a problem since.
4fords.
Old Aug 21, 2006 | 08:42 AM
Racerguy's Avatar
Racerguy
You're right in that the ground is through the driver's switch but since dizzead's window works one direction that means the ground is good. The switches change polarity depending on if you have it in the up or down position.
Old Aug 24, 2006 | 12:22 PM
984x4F150's Avatar
984x4F150
I have a somewhat similar problem. My passenger window just started not working intermittently, then just quit working one day. It took it about 2-3 weeks to go from once in a while to nothing, and I don't use it that much. It never went slow or anything, just suddenly quit. I'm hoping it's just the switch, but I don't know how to check to find out. Would one of you knowledgeable people be able to tell me how to check the switch, and what kind of voltage I should be looking for? I do have a digital voltage meter, just don't know what to check and what to look for.
