I can't roll the window up!
The passenger side power window in my '04 F150 will not roll up. Most importantly, how do I get it back up? I have the door panel pulled off and have tried to push the window back up from the bottom. No luck. The window will not budge.
When I try and operate the window switch I can hear the motor briefly, than nothing. I have tried to tap the motor as well while holding the switch in the down position. Still nothing and I need to get the window up before the vagrants in my apartment complex decide to molest my truck. HELP!
i would try the door switch first and if that doesnt work, hook direct power to the motor and see if it runs. no motor run then you have a bad motor, after that i would look into relays and fuses and then its chasing wires but i dont think its wires. it will be a hard componite or fuse or something
