1978 - 1996 Big Bronco
drivers side window won't move
Old Feb 4, 2005 | 11:22 AM
jason86's Avatar
jason86
The drivers side power window on my '86 Bronco is now not functional. It is 3" down and won't go up or down. How can I tell if its the switch or the motor?
need help,
Thanks
Old Feb 4, 2005 | 11:43 AM
dwoodler's Avatar
dwoodler
Try using a test light on the switch. If there is power thru the switch then it's the motor. You could also try jumping the window actuator.
Don
Old Feb 4, 2005 | 11:46 AM
tHeCoS's Avatar
tHeCoS
can you hear the motor? If you can then the regulator needs rebuilding. There are these 3 round plastic wedges inside the regulator. They go bad and break apart. Goto the local autozone. They have them at the HELP section. If you don't hear the motor, then check the wiring and the fuse. hope that helps
Old Feb 4, 2005 | 11:47 AM
jason86's Avatar
jason86
Question
ok, any idea what wire should have power?
Old Feb 4, 2005 | 11:56 AM
tHeCoS's Avatar
tHeCoS
off hand I dont remember which wire but your test light will
Old Feb 7, 2005 | 09:40 AM
BroncJMU's Avatar
BroncJMU
I've replaced my 86's motor a couple of times now. The current motor will occasionally freeze up when it is either in the totally up or down positions. It sounds dumb, but try slamming the door a couple of times, or hitting the motor with a hammer. I guess the gear locks up sometimes.
Unless it is one of the forementioned electrical problems.
Old Feb 8, 2005 | 09:10 AM
jason86's Avatar
jason86
It ended up being my motor. Funny thing was it was a new motor, barely 2 years old. It was made in India too. I replaced it with a used one from a Bronco II.
(a little tip - If you find out you have a passenger side by mistake you can still make it work by mounting it up side down and reversing the wires.)
Old Feb 8, 2005 | 12:40 PM
tHeCoS's Avatar
tHeCoS
huh? upside down would be the same as right side up. The reverse direction of the gear would be the change..yes?. my brain hurts!
Old Feb 8, 2005 | 02:58 PM
jason86's Avatar
jason86
yep. you're right. You don't have to reverse the wires, i didn;t on mine, only if you want to function as it did before. 1980-86 window switches aren't even marked up-down so that why I didn't worry about it. Save you brain for my next problem.
2000 X
Oct 24, 2011 10:53 AM
rolltide3006
Jul 7, 2011 11:43 AM
Frankiels3
Apr 26, 2011 10:55 PM
pablocruz69
Mar 28, 2009 11:44 AM
greyfox503
Feb 17, 2008 09:55 AM
