Sponsored by: Auxito
Power window issue
Old Jul 15, 2017 | 06:12 PM
pounder90's Avatar
pounder90
Power window issue
My driver's door power window motor stopped working. Replaced motor (Dorman). New motor was shaky and wouldn't stop when going down. Replaced motor again (Dorman), same thing. Regulator became damaged, replaced (Dorman), smoother, still won't stop with auto button, or holding down button. At some point glass came out of regulator and track. Replaced glass. Window goes up and down smoothly, but just doesn't stop when going down and tries to keep going. I don't see a limit switch or circuit for it. I see there is a relay and a fuse for the auto down. What tells the motor to stop driving current? Thank you.
Old Jul 16, 2017 | 09:21 AM
alloro's Avatar
alloro
The GEM controls turning off the power to the motor during the Auto Down function. The other possibility is the window switch is sticking.
Old Jul 17, 2017 | 11:03 AM
pounder90's Avatar
pounder90
Thank you for the GEM info. I don't believe the switch is sticking because holding down the passenger side switch doesn't cause it to keep going and the motor stops when going up when the switch is still depressed. Is this a known failure for the GEM module? I'll swap it out, but hate to shotgun parts. I was hoping someone had fixed the same issue that could advise, or provide some troubleshooting guidance to pin point the problem. Thank you
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
pathfindertango
Feb 20, 2015 01:20 PM
hugo0612
Sep 17, 2007 10:09 PM
aMw_fl
Apr 13, 2007 12:55 PM
dizzead
1997 - 2003 F150
Aug 24, 2006 12:22 PM
