Power loss...
Old Sep 2, 2013 | 06:47 PM
JOHN2001's Avatar
JOHN2001
Power loss...
So I'm still chasing a power loss I can't find. I'm making 33 psi boost egts seem to be in check. No codes. I thought maybe it was a fuel issue so I did the hutch and harpoon mod and added a fuel pressure gauge, I'm at 72 at idle and drops to 58 at wot. I don't believe it is an air issue because I'm making thy kind of boost. Everything seems to be there to make the power I should be but for some reason or doesn't.
I have noticed lately that the truck rolls a lot more black smoke than it normally would in my 80e tune so much so that I stopped running it in that tune in favor of the 60e which still seems to smoke a lot more than I like. For instance driving down the road at 60 mph with cruise set on flat road I came up on a rail road bridge that I had to go under (30' drop 30' rise) the truck kicked out of over drive down to 3rd rolled some serious coal just to make it back up this stupid little hill. A dip in the road like the that one should never cause a truck let alone a 7.3 to have to drop out of lock up.
Any good ideas? I've been trying to figure this out for over a year now.
Ask any and all questions
Old Sep 2, 2013 | 08:20 PM
snakedoc's Avatar
snakedoc
how old is the air filter?
Old Sep 2, 2013 | 08:24 PM
F-250 Super Duty's Avatar
F-250 Super Duty
How's the air filter look? Fresh one in there? Pre-filter not dusted up?
Old Sep 2, 2013 | 08:35 PM
diehardstroker's Avatar
diehardstroker
is your oil level unusually low?
Old Sep 2, 2013 | 08:43 PM
tappit01's Avatar
tappit01
have you ever cleaned the ebps tube?
JOHN2001's Avatar
JOHN2001
Air filter has less than 3k miles on it. Oil level is perfect
Old Sep 2, 2013 | 08:44 PM
JOHN2001's Avatar
JOHN2001
Yes I just did this about a month ago. It wasnt clogged and I also cleaned the sensor.
Old Sep 2, 2013 | 08:47 PM
diehardstroker
I looked in your sig what are you running for a regulated return for the fuel pressure to be that high at idle? frx?
Old Sep 2, 2013 | 09:14 PM
JOHN2001's Avatar
JOHN2001
Why it's that high I have no idea. It could be due to a faulty gauge. My fuel pressure gauge went nuts on me a couple weeks after I installed it. Ill be sending it back under warrantee later this week. Other than the in tank mods the the fuel system is bone stock. I opened a thread on my fuel pressure shortly after observing it for a little while and the end result was that there is no issue with running that pressure.
I've pretty much exhausted everything that I could come up with that might explain the loss of power. It's been a slow loss over time... Lots of time
Old Sep 2, 2013 | 09:45 PM
diehardstroker
ever done a cylinder contribution test? do you have a lot of blowby?
Old Sep 3, 2013 | 04:34 AM
JOHN2001's Avatar
JOHN2001
Nope and nope
Old Sep 3, 2013 | 06:09 AM
diehardstroker
what does your oil pressure look like when it does something like you stated about going under the bridge and really blowing some smoke?
Old Sep 3, 2013 | 06:14 AM
Tugly's Avatar
Tugly
This might be the issue that is being discussed here [LINK].
Old Sep 3, 2013 | 08:45 AM
JOHN2001's Avatar
JOHN2001
Oil pressure stays the same or at least close enough the gauge moving doesn't catch my eyes and LPO is the middle gauge in my pillar so it's in my face.
Tugly, which part are you talking about? Post #? My phone is jumping and skipping to random pages every time I click on your link.
Old Sep 3, 2013 | 08:50 AM
diehardstroker
Here's my suggestion, pull the chip and see how the truck runs. You might have a bad connection with the pcm, maybe it wiggled a little loose over time....
Ik when my truck was stock (without chip) it wouldn't pop out of lockup for a hill like you described
