Replacing oil cooler. What else should i do while there
Old Jul 20, 2013 | 10:21 PM
BryanStein's Avatar
BryanStein
2004, f250, 6.0. 216k miles. EOT/ECT delta about 30 degrees. Tuck runs great.
Egr delete, HPOP, and new oil cooler 50 k miles ago, but it appears the oil cooler is clogged again. Perhaps they didnt flush the coolant system when it was changed.
I can't prove the egr delete is installed. Still has the egr chamber with coolant running through it. Still had the egr valve. I can't see if a plate was installed in the up pipe to egr cooler connection. So, I can't prove it has an egr delete.
I'll order a sinister just in case. I'll also install a coolant filter.
I've read where the turbo oil feed and drain lines should be replaced.
What else should I get for the model truck while there. If if were a later model, it would be stand pipes, dummy plugs and stc connection. This model had the hpop problem, but that has been changed already.
I thought about the fuel pump blue spring upgade, but that is easy enough to do anytime.
Thanks for the help.
Old Jul 21, 2013 | 08:47 AM
Corner Gas's Avatar
Corner Gas
If you haven't I would check your head gaskets if you are going in to do that work. The other stuff I would replace also just because you are in that far and the parts aren't to expensive.
Old Jul 21, 2013 | 09:12 AM
RPM371's Avatar
RPM371
You might consider a Bulletproof oil cooler. A lot tougher than OEM, but they are expensive.
Old Jul 21, 2013 | 09:40 AM
BryanStein's Avatar
BryanStein
Corner,
You say other stuff. What is other stuff on an 2004 that has had the hpop replaced already?? That's what I am asking.
How do you check the head gaskets without pulling the heads? Tuck runs great but it does not have head studs. The guy I bought it from said he was told it got a new engine just before he bought it at 150k miles. I don't know how to verify that without pulling the engine to look at the stamp.
RPM, the check book can't take the BPD oil cooler. I'm not a big fan of it anyway.
Thanks for the input, guys
Old Jul 21, 2013 | 09:44 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Not much to check, but maybe pop out the IPR and make sure the screen is ok.
Josh
Old Jul 21, 2013 | 09:49 AM
BryanStein's Avatar
BryanStein
Thanks, bullet. I hadn't thought about that. The IPR is on the passenger valve cover, right?
Should I replaced the turbo oil feed and drain lines?
Old Jul 21, 2013 | 10:22 AM
Corner Gas's Avatar
Corner Gas
Originally Posted by BryanStein
Corner,
Sorry other stuff was to general, I meant turbo drain tube and IPR screen
and the ICP sensor. There is a sticky about how to check the HG's, basically you hook a line to the degas bottle and run a line to the cab with a pessure gauge and drive the truck hard and if you go over 16 psi there is a good chance you have a blown HG.
Old Jul 21, 2013 | 10:34 AM
Bullitt390's Avatar
Bullitt390
IPR is on the turbo.
03 to early 04 ICP is on the turbo. 04.5+ is passenger valve cover
Josh
Old Jul 21, 2013 | 10:59 AM
vloney's Avatar
vloney
Josh
Its not on the turbo (IPR), its behind it. ICP never is on the turbo, 03-04 behind the turbo.
Old Jul 21, 2013 | 11:32 AM
Bullitt390's Avatar
Bullitt390
Sorry, that's what happens when you type on an iphone while walking the dog.
Josh
ChalmersP
Aug 20, 2017 06:39 PM
glenalt
May 26, 2016 11:19 AM
Jimbo532
Jul 9, 2013 10:37 PM
exy
Aug 11, 2011 05:50 PM
Bordercollie61
Sep 27, 2010 03:10 PM
