Gauge
Old Jul 25, 2013 | 03:00 PM
  #76
Lilpooh's Avatar
Lilpooh
Originally Posted by GSlahor
Thanks RPM371.
I didn't realize that ICP was the same as HPOP
Just a note: if your running a tuner, some tunes give a lower ICP reading thru the OBDII. This is just one way that the tune writer fools the ECM into more power. ICP at WOT will be just above 4000 psi.
Old Jul 25, 2013 | 04:36 PM
  #77
diesel_dan's Avatar
diesel_dan
Originally Posted by jimh425
Thanks for keeping this thread alive. I didn't realize there were apps readily available. I was actually looking for a coupon code for Scanguage II when I found this thread. I just bought a Bluetooth OBD adapter off ebay. I'm assuming it will work.
Assume you have a Droid device? If you need help there's a bunch of us using Torque Pro and lovin' it
Have you done a blue tooth pairing? It's basic and most of the adapters will work, some get more static data than others. You want ELM327 V1.5 or higher -- I got a mini one with No lights pointed at the passenger area (gets distracting at night).
Set up a Google wallet and go into GooglePlay and buy Torque and when you set it up you'll want to pull in the Ford specific PIDs. I'm getting ahead tho... Get your stuff and let us know what hangs you up. Prepare yourself for a whole new world!
Old Jul 26, 2013 | 08:15 PM
  #78
deeno360's Avatar
deeno360
For you dashboss guys, what instant MPG are you guys getting....Mine reads 1.5 -5.5 MPG??? I KNOW I'm doing better then that!
Old Jul 26, 2013 | 08:18 PM
  #79
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The DashBoss MPG pid is for gas engines, it doesn't work with the MAF and the 6.0
Josh
Old Jul 27, 2013 | 09:16 AM
  #80
deeno360's Avatar
deeno360
That would explain it! Thank you
Old Aug 1, 2013 | 08:16 AM
  #81
GSlahor's Avatar
GSlahor
Where to tap coolent pressure ?
I'm purchasing some pillar mount analog gauges...... EGT...fuel pressure and coolent pressure.
Anyone have any experience with an easy place to tap into the coolent pressure ?
TIA............
Old Aug 1, 2013 | 08:30 AM
  #82
Misky6.0's Avatar
Misky6.0
TIA............
One thing you might consider, is putting in a single "pressure" gauge and then installing one sending unit for fuel pressure and another for coolant pressure and another for oil pressure if you feel so inclined..
Then rig up a switch to switch the gauge between the various sensors. Not really a need (IMO) to view each gauge continuously.. I also found a company (spatechique) which makes a standard-size digital gauge with two displays in one. (see my sig).
Old Aug 1, 2013 | 08:55 AM
  #83
Benchwrench's Avatar
Benchwrench
Interesting request.
In the early 80's (the good ol' days) I recall having several Stewart Warner gauges in my 68 RS Camaro, even a cyl head temp gauge, remember those?
Well, one of them was a mechanical oil pressure gauge that routed oil via a translucent poly line up under the dash, (the same style and size line you'd see/use on air shocks) one evening out with a buddy the line broke nearly in half and we had stinking pressurized oil pouring into the car. My loyal buddy put his thumb over the hole to stop it but it was too hot and too much pressure in such a small line, I think what I ended up doing after freaking out a while was to take a lighter, melt then pinch the end of the poly line to stop the hemorrhage. (the things you do when young and dumb...)
A coolant pressure gauge will have to be electrical just like oil pressure, I don't think anyone would want hot fluid pouring out when the hose is compromised.
One of the best places to tap that I can think of would be at a high point such as the degass bottle.
Old Aug 1, 2013 | 01:10 PM
  #84
MisterCMK's Avatar
MisterCMK
They check for nylon line on the oil pressure gauges during tech at drag strips. My Mustang has nylon line on the oil pressure gauge and at Brainerd International they mentioned it to me. I was still able to race the brackets that day but I need to replace that line with copper when I put the blower on.
Old Aug 1, 2013 | 01:16 PM
  #85
Bullitt390's Avatar
Bullitt390
Just Tee into either of the rubber lines and run a ground wire to metal.
I should be getting around to hooking one up in a couple weeks.
Josh
Old Aug 1, 2013 | 04:41 PM
  #86
Misky6.0's Avatar
Misky6.0
Yep, those are "mechanical" gauges vs. "electronic" gauges with just wires running into the cab. I installed a set of mini-gauges into my '80 firebird, neighbor had a machine shop and he cut my dash to fit the 3 gauges where the Trans-Am gauges would have been. Worked great, until one day going to work I noticed no oil pressure. Looked under and found a small trail of oil where the plastic-like hose had touched something HOT and melted. Luckily didn't loose much oil (was almost to work when it went apparently). Fixed it after work and cable-tied it out of the way (ah, to be 18 again).
I only use electronic gauges now.
Old Aug 7, 2013 | 03:02 PM
  #87
deeno360's Avatar
deeno360
I have the dashboss and love it....looking to do the blue spring upgrade on my 05 6.0L and would like to be able to read fuel pressure real time....
Is the $30.00 pressure sensor from the Dashboss guys all I need?
Old Aug 7, 2013 | 04:18 PM
  #88
Bullitt390's Avatar
Bullitt390
Yes, the sensor with pigtail
Josh
Old Aug 7, 2013 | 04:54 PM
  #89
Lilpooh's Avatar
Lilpooh
For fuel psi. Your gonna need a adapter that goes from M12-1.5 male o-ring to 1/8npt female. You can either use a isolation hose or hard plumb the sensor to the port.
Old Aug 7, 2013 | 07:30 PM
  #90
rayezra's Avatar
rayezra
Help me braille my way thru this.
Not that I mind Googleing for the parts for the fuel sensor, but I just do not want to mess anything up.
So to hook into my Dashboss for Fuel Pressure I buy -
Pressure transducer 0-100 psi | Dashboss - Critical Vehicle Health Monitoring
And Lilpooh you say I need adapter (we have the same year truck btw) If I go into Napa and say I need: M12-1.5 male o-ring to 1/8npt female
They will know what adapter that would be? Or do you have a part number?
Any snaps where to hook this? An idiots guide?
Thanks again guys!
