Gauge
Old Jul 23, 2013 | 11:54 AM
  #61
rayezra's Avatar
rayezra
Man I just gotta say, while I am a "fanboy" of the Dashboss, I do love the look of those gauges.
I might have to do a left pillar set. I remember riding in a diesel (before I had one) that had a set and thinking how cool they look. Not that I really spend $ on looks for my truck but I see a benefit. And I am a budding private pilot - we likey gauges....
Old Jul 23, 2013 | 12:06 PM
  #62
Benchwrench's Avatar
Benchwrench
A bit of redundancy is ok in my book.
I chose carbon fiber cups and modified each gauge bracket to sit lower. Converting the LED's to Green keeps the cockpit looking uniform.
Old Jul 23, 2013 | 01:17 PM
  #63
Misky6.0's Avatar
Misky6.0
There is a company which makes digital gauge which reports 2 different values in a single gauge... I have the FP & Volts, although I am second guessing myself I should have got FP & EGT and just stuck a simply digital voltage gauge into the cigarette lighter....
Dual Gauges
When you factor in the amount of space you save, less mounting HW, wiring, etc. the price is less shocking..
Old Jul 23, 2013 | 01:25 PM
  #64
MisterCMK's Avatar
MisterCMK
I'll take my edge insight which sits on the dash in a nice molded mod, never needs batteries, displays 8 things at once and just plain works.
Old Jul 23, 2013 | 02:31 PM
  #65
GSlahor's Avatar
GSlahor
HPOP press source ?
There is an analog gauge the measurers HPOP Pressure
Anyone know where you tap in to get the pressure ?
Is it straightforward, or a PIA ?
TIA................
Old Jul 23, 2013 | 03:02 PM
  #66
Benchwrench
I use the radar detector for reading Volts.
Old Jul 23, 2013 | 03:13 PM
  #67
Benchwrench
Dual Gauges
SPA's the way to go if you want digital gauges, they include programmable warning limits that'll get your attention if out set parameters. I almost went that way but obviously chose analog Autometers to match.
There's lots of choices out there these days.
Old Jul 23, 2013 | 03:55 PM
  #68
Lilpooh's Avatar
Lilpooh
TIA................
Yes, Autometer and others. Then all you need is the HPOP pigtail plug, or splice into the ICP factory wires.
High Pressure Oil Gauge Install Pigtail
Old Jul 23, 2013 | 04:02 PM
  #69
snorindad's Avatar
snorindad
BPD sells the school II for 169 fully programmed for the 6.0l. For those who do not want to program it themselves.
Old Jul 24, 2013 | 06:31 AM
  #70
GSlahor's Avatar
GSlahor
Which analog gages to suppliment Scangage ?
For my 3 analog gage pod, which are the best three gages to install to suppliment what I already have in my Scangage ? Choices include:
EGT - pre turbo
EGT - post turbo
Fuel Pressure
HPOP pressure
Coolent pressure
Others?
Old Jul 24, 2013 | 08:40 AM
  #71
Rusty Axlerod's Avatar
Rusty Axlerod
Scan gauge reads everything but low side oil pressure, fuel pressure, and EGT. (And coolant system pressure).
Old Jul 24, 2013 | 09:22 AM
  #72
GSlahor's Avatar
GSlahor
HPOP from Scangage ?
Is it true that HPOP can be read from Scangage ?
I didn't see it listed in either the list of standard gages, or the Xgages.
Can anyone supply the appropriate TDX, RFX, RXD and MTH values ?
Many thanks.............
Old Jul 24, 2013 | 11:40 AM
  #73
RPM371's Avatar
RPM371
Yes it will read it as ICP.
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
Here's a great thread with just about every code you want.
Monster-4 put together a pretty good list of codes.
Old Jul 24, 2013 | 12:17 PM
  #74
jimh425's Avatar
jimh425
Thanks for keeping this thread alive. I didn't realize there were apps readily available. I was actually looking for a coupon code for Scanguage II when I found this thread. I just bought a Bluetooth OBD adapter off ebay. I'm assuming it will work.
Old Jul 24, 2013 | 12:44 PM
  #75
GSlahor's Avatar
GSlahor
Thanks RPM371.
I didn't realize that ICP was the same as HPOP
