July BS Thread
Pulled motor, disassembled, cleaned, painted, new valve seals, heads back on, new cam/lifters, valvetrain together, belt drive timing set, engine bay cleaned and painted, misc parts cleaned/painted
Need to buy a new oil pump pickup as the new HP/HV pump takes a different style and need to get a rebuild for the carb I don't want to run but don't have the cash for an Edelbrock, pisses me off cause last year I had 20 Edelbrock carbs on my shelf and sold them as I expected to keep getting them from work
Dylan are you bringing the bug to the next meet?
I can bring a REAL timing light. It even reads RPM
or if you get ambitious come on over and do it here.
I got a ner floor jack 4 ton one. Now I can off that Sears
PITA. It still works just don't lift 8K trucks with it. Well
I was only lifting a corner and what not.
Sean
Sean
). I don't remember where you live/how far you are but going to your place could be a possibility for a later day.Pulled motor, disassembled, cleaned, painted, new valve seals, heads back on, new cam/lifters, valvetrain together, belt drive timing set, engine bay cleaned and painted, misc parts cleaned/painted
How much do you have to spend? I took a peak on eBay and found 2 sorta cheap ones. They aren't in the best condition and will need rebuilds though.
http://www.ebay.com/itm/Edelbrock-4-barrel-1407-Series-Carburetor-Used-750-CFM-/231016411800?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c9a6b298&vxp=mtr
This one is a little higher priced but in better condition.
http://www.ebay.com/itm/edelbrock-1407-carburetor-/121144340686?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c34c3f0ce&vxp=mtr
Also my neighbor across the street is always working on a car. If you've got a base price I can see if he has any or knows anyone with a cheap one.
Down on Canyon Road? It would be easier to come to your place at some point rather than trying to tune it in the Jimmy Mac parking lot. I only need about $20 worth of gas in the bronco and It will make it there and back no problem. The bug probably doesn't need any gas but again, I think it would be easier to take our time to poke around with it.
Dang!!! Someone wake up Ole.....lightnin dun struck the bunk house!!!
My Miss Rose was picked for the FTE Truck Of The Week honors!!
Whoa....seriously surprised, humbled and feelin just a lil bit whoopass.
Thought I'd share with my fellow NW'ers.
Capt'n
Capt'n
I saw that both on FaceBook and when Steve posted a thread about it here. Congrats bud! That's an awesome ride.
I will come up with a carb eventuly. Have a Holley to run at the moment and with my motor being a cammed 460 with an intake and exhaust the 600CFM 1405/1406 carbs are a bit on the small side.
Got my cam timing set with the new belt drive, cleaned/painted a lot more including engine bay, about done plumbing my Hydroboost.
Found out the reason people don't do work parties for bachelor parties is that nobody shows up, only 2 have showed and due to that I am only doing the motor swap and a lot of clean up/painting/wiring and the frame splice will have to happen later as with 2 people and my bad back there's no way we could "wheelbarrow" the truck halves around. Another guy I know just got a house Monday that has a 60X40 shop and already planned to move all my tools and everything there so after that is all set up and he is moved in and ready I will buy heavy duty casters and make legs to roll around the truck halves and do the frame splice myself.
Well Done
Sean
Sean
Hey Sean, What brand of jack did you buy? I need or want a bigger jack mine still works but bigger would be better.
Found out why people complain about ProComp Electronics products, the belt drive timing set I paid $400 for (on sale) would not work with a stock water pump so I paid $180 for a Moroso pump that would work with it and the Moroso pump wouldn't accept ANY factory accessories cause the shaft was 2" lower than a regular pump. So tore it all off and from the tolorances on the belt drive being so off the only way to remove it was destroy it.
Going to an RV timing set under a stock cover and have $600 worth of paper weights. NOT a good day!
OK so I just looked up that timing belt, why wouldn't a stock water pump work? Looks like you just use a stock water pump backing plate?
Cause you need the dish in the back of the plate and that wouldn't clear?
Why not skip the whole belt driven water pump thing and just use electric if your doing all this?
Just curious
Just curious
Floor Jack with Rapid Pump®, 4 Ton Heavy Duty Steel
Here is the photo of the one I got
I have not put it to use yet. Too much going on right now.
Sean
my harbor freight aluminum floor jack has had no troubles except screws/nuts rattling loose. use some loctite to make sure your jack will stay together, and it should treat you just fine.
my harbor freight tranny jack is a different story that we've already told
