Weird engine start 6.0
Old Sep 15, 2013 | 10:44 PM
  #106
run6.0run's Avatar
run6.0run
Originally Posted by King Kerosin
Little update...
I replaced the HFCM with a new one from rockauto. What a mess!!! Still the same. All the values I checked with the Scan gauge seemed to be like they should. I think it's an injector. When I accelerate when engine is cold, I have misfires. Like one cylinder wouldn't fire proberly. I start hating that truck!!
Is the sg2 showing misfires?? Btw, did you pay the $4.99 for the torque app?? If so, if you go into the settings there is a powerstroke download that is included in the app. But it has to be manually downloaded
Old Sep 16, 2013 | 10:02 AM
  #107
Per4mance's Avatar
Per4mance
Is it multiple missfires or just one missfire if it's multiple you better have Ed ck that ficm or the harness
Old Sep 16, 2013 | 06:38 PM
  #108
King Kerosin's Avatar
King Kerosin
I replaced the HFCM Unit.
But If it were the glow plugs, why would it take 10 Minutes to make the truck run ok? Even with a broken glow plug, it should run normally after 1-2 minutes.
Not sure what could be the problem with the ficm. I monitor the voltage, which is always 48-48.5V.
Could that still be the problem? That would be crazy, cause the truck runs just perfect, once warmed up.
Old Sep 16, 2013 | 09:23 PM
  #109
BryanStein's Avatar
BryanStein
Agreed, King. The gps do nothing after 5 minutes.
I'm leaning towards stiction. A misfire when cold only is a good indication of this.
Old Sep 17, 2013 | 09:36 AM
  #110
King Kerosin
Yes me too. Is there anything I can do to the injectors besides some fluids you pour in the tank?
How can I find out which injector is the problem?
Old Sep 17, 2013 | 04:57 PM
  #111
BryanStein's Avatar
BryanStein
Obviously a contribution balance test ONLY when cold would do it. Mine aren't bad enough yet and runs great within 2 minutes of running. Mine won't stick unless it sits for several days. Cranking after an overnight soak doesnt show any problems.
A buzz test might do it, but it must be after a long soak to cool down.
Archoil is supposed to be the latest miracle additive. I just got mine delivered, so I haven't tried it yet.
Old Sep 18, 2013 | 10:23 AM
  #112
King Kerosin
Hi. Which Archoil are you going to try? AR 6000 fuel treatment. Please let us know if it helps. Maybe I'll give it chance too.
Old Sep 18, 2013 | 04:16 PM
  #113
BryanStein's Avatar
BryanStein
Added the 6200 this morning. I put in 50 ml on a 25 gallon tank of fuel on top of my cetane additive. I thought it felt smoother within two minutes, abs I wasnt even trying to notice it .... But I did notice. However, I'm reserving judgement until after I run two tanks at double the recommended dosage.
I actually measured the decibles thus morning before adding the 6200. I'll measure it again after two tanks. My injectors are pretty loud.
I also have the 9100 oil additive that I will add at my next oil change. I want to change one thing at a tinge and see the diffeence. I think I'll stop the 6200 when I add the 9100 to the oil and run a few thousand that way before using the rest of the 6200. If I see a big difference, I'll keep running both.
Old Sep 18, 2013 | 07:48 PM
  #114
04badford's Avatar
04badford
Last winter I had some real bad cold starts Changed the Oil to a Rottella 5w 40 synthetic and I put in 4oz of RevX . My truck starts on a turn of a key and No rumble when cold for $30 bucks I'm a believer.
Old Sep 18, 2013 | 08:36 PM
  #115
King Kerosin
Yeah maybe I'll try that also. But I'll wait until winter, also.
Btw is there a possibility to check the turbo?
It's an aftermarket/ replacement turbo. Maybe that's the problem.
Old Sep 18, 2013 | 11:14 PM
  #116
BLADE35's Avatar
BLADE35
Post#113 and Things sounds like there Getting Desperate LOL
Or on the tip of Throwing Parts
No I didn't read all 113post LOL
Old Sep 18, 2013 | 11:30 PM
  #117
BLADE35's Avatar
BLADE35
Originally Posted by 04badford
well If that's it, I did try to say something back when the pics came up and then I kinda forgot about it until last nite when I went back thru your posts any how, lets hope the guys will Chime in .when you have time maybe look at it and see if its pop up still?
This is a F$%Ked up thread Are the Pics Big Enough Think we Could Blow them Up to Say a Coouple Mile Area Pic and Look at it Like we was Flying Over in a Plane LOL
I see its Broken
And if you Look Into the Pic that Show the Inside the Filter there a Big Looks Broken Piece there too
See That
Old Sep 18, 2013 | 11:44 PM
  #118
BLADE35's Avatar
BLADE35
That's weired, is the upper fuel bowl cap the same as the HFCM, in the old pics just wondering if the two pics were mixed because there were filters changed and I don't see the same image with the new pics .
Its there in the First page that Washer was Hanging there
and It looks Gone in the second round Pics
Old Sep 19, 2013 | 10:14 AM
  #119
King Kerosin
In the filter was never a washer or something broken. And yes, I'm getting desperate. Even thinking about selling it with loss.
Old Sep 19, 2013 | 09:12 PM
  #120
BryanStein's Avatar
BryanStein
Not a big fan of additives, are we, Benny?
