Weird engine start 6.0
Old Jun 11, 2013 | 06:20 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Just to go back to the oil filter for a second. Here's a pic of the correct one. Using the wrong filter and cap can cause start issues.
Old Jun 11, 2013 | 08:21 PM
King Kerosin's Avatar
King Kerosin
I thank you guys for all your advices.
I already read about the "wrong" filters. To make sure, I will pull the filter tomorrow again, and take some pictures. Unfortunately, I forgot the brand from the filter.
The humidity here s today at 8%.
Actually I'm not a big fan from any fuel or oil adds...
Old Jun 12, 2013 | 12:27 PM
King Kerosin
Morning guys!
I just pulled the oil filter. Here are some pics. Looks pretty much ok:
I also pulled the main fuel filter. Nothing abnormal, huh?
Daniel
Old Jun 12, 2013 | 12:42 PM
Maxium4x4's Avatar
Maxium4x4
Looks good from I can see. Use caution when replacing the HFCM filter, install the new O-Ring as supplied, lube and tighten. If not done correctly it can suck air but will not leak fuel.
Old Jun 12, 2013 | 12:53 PM
King Kerosin
Man, why are those pictures so small??
Here's a link to the whole album. Hope this works.
Mitgliederbereich zum Bilder hochladen
Old Jun 12, 2013 | 02:12 PM
Maxium4x4's Avatar
Maxium4x4
Your link is to a members area, I would have to log in. You may have copied the thumb nail picture. Kommen Sie aus Deutschland?
Old Jun 12, 2013 | 02:39 PM
King Kerosin
Yes, I do! I'm in the states with the german air force.
Ok, I'll try to fix that later.
Old Jun 12, 2013 | 03:00 PM
King Kerosin
Old Jun 12, 2013 | 03:05 PM
King Kerosin
Btw.: Is that the filter for the automatic transmission?
Is there a second one in the pan?
Daniel
Old Jun 12, 2013 | 03:25 PM
Maxium4x4's Avatar
Maxium4x4
Wow that truck is a rust bucket, must of originated from Ohio The last picture is the transmission filter, the screen in the pan is just to catch the big pieces if you have a failure. Use an air impact and metric socket to remove the filter canister, by hand the filter housing bracket will just twist.
Ich spreche nur Englisch, wie ich Google Übersetzer verwende
Old Jun 12, 2013 | 03:31 PM
King Kerosin
Ok, changing the filter can't hurt. Will do that tomorrow.
Thanks for you help!
Old Jun 12, 2013 | 10:12 PM
04badford's Avatar
04badford
WOW, filters need a lil TLC ,but there OEM with OEM cap, thats a big + , try to use a socket on the cap and just snug them dont over tighten , useing a pair of Channel locks will crack the cap, and drain water sep on the lower fuel rail .
Old Jul 8, 2013 | 02:57 PM
  #28
King Kerosin
Hi,
I checked the FICM today. I got the 4 pin version. It has 48,2V Key on engine off, and 48,5V Key on engine running.
Any other ideas? I really wanna get that fixed...
Most annoying is, that the truck runs pretty bad, when it's cold. Once warmed up, it runs like a champ.
Old Jul 8, 2013 | 05:36 PM
  #29
04badford's Avatar
04badford
Originally Posted by King Kerosin
Hi,
Back in the second pic the washer in the center is bent upward is that in the oil res ? now that the weather has warmed up does the truck cold idol a little easyer,If not I would think Inject, try revx oil treatment its a $ 30.00 fix ? .I added one to mine and truck starts and Idols great cold
Old Jul 8, 2013 | 05:42 PM
  #30
npccpartsman's Avatar
npccpartsman
Hi,
...Most annoying is, that the truck runs pretty bad, when it's cold. Once warmed up, it runs like a champ.
Sounds like a case of injector stiction to me. What kind of oil and filters are you running? OEM filters and 5w40 synthetic might help you also.
