a4ld torque problem
Old May 25, 2013 | 04:53 PM
daniel77's Avatar
daniel77
a4ld torque problem
Hello every one . I am new to this site but have been a ford man all my life . Love working on fords .To tinker or repair them .
I have ran into a problem I cant figure out . I have a 94 explorer . The
reverse went out . I got another tranny from the bone yard . They took the torque coverter out . And I can not get it to go back in . Any help from any one
Old May 25, 2013 | 06:18 PM
KhanTyranitar's Avatar
KhanTyranitar
Well, for starters the unit you got out of the junkyard is well, junk.
You have to get everything lined up correctly. You should be installing a new torque converter. I myself have always opted to rebuild the old transmission.
Old May 26, 2013 | 08:25 AM
daniel77's Avatar
daniel77
help putting turque converter in
Thank you for you help . But I dont have $2 gs to rebuild the tranny .
I know this is a good tranny . The bone yard took the torque converter .out to put tranny in my truck . now I can not get the torque to drop in . Not even the first drop . What do you mean everything has to be lined up ?
There is a small shaft in side the big shaft . How far does the small shaft stick out from the big shaft ? Please people can a Little help with this .
If I was to rebuild this tranny and have this same problem .How would I
fix it . Any help ?
Thanks Joey
Old May 26, 2013 | 12:21 PM
Ford_Six's Avatar
Ford_Six
You have to push the torque converter on while rotating it. Just a little back and forth should do it until it gets to the pump drive, then you'll probably need to twist it a bit further. There should be three steps to it.
Old May 26, 2013 | 11:45 PM
KhanTyranitar
Yup, you have to rotate the torque converter until it fully engages and seats where it should, and as you push the engine and trans together, all the parts have to be perfectly aligned.
What makes you think your trans will cost $2000 to rebuild?
All you need is a valve body rebuild kit and a couple other parts, if you do it yourself, $500 is typical, $900 at most (if there is a lot of hard parts damage). When done correctly you get a trans thats better than new. A used trans is nowhere near new condition, you might get a year or two, assuming that it hasn't been improperly rebuilt previously.
Old Jun 1, 2013 | 05:53 PM
daniel77's Avatar
daniel77
torque converter problem
huh
got my torque converter in . The center shaft had a few burs on the
teeth . Would not let torque converter to slide on . Lightly filed the teeth.
converter side right on . All works perfectly . But now I have no reverse lights
Replaced the nutral safety switch . Checked bulbs . Checked grounds .
No reverse lights I m lost . Might have to pay a few hundred to have a tranny shop look at it . Hell who needs reverse lights ?????????????
Joey
Old Jun 1, 2013 | 11:57 PM
Ford_Six's Avatar
Ford_Six
Double check the adjustment on the switch, and for Murphy's sake check the bulbs-
Old Jun 29, 2013 | 06:57 PM
daniel77's Avatar
daniel77
thanks Ford six . But what do you mean "check the adjustment on the switch" ? It just screws in to the transmission and you hook the wire up . How do you adjust it ???????
Old Jun 30, 2013 | 06:05 AM
oneowner83's Avatar
oneowner83
I would put a test light on it to see where you lose a signal
bsymes34
Nov 8, 2004 11:13 AM
bell47g2
Aerostar
Mar 7, 2004 02:40 AM
motobub
Apr 11, 2003 06:18 AM
78blueford
Dec 16, 2002 05:36 PM
