Well I did my oil and fuel filters today. I did find that with the tank less than 1/4
I did not take a bath in diesel. The last time I changed it I took a bath. So I guess
the next one I'll make sure that the tank is low again.
This was also the first time I have ever gotten any water from the drain. Less
than a tablespoon.
I wear my Grubby clothes when changing the frame filter and leave them outside to air out for a while! I like changing that filter with drivers side on the curb of the street.
In the past I most likely had a full tank. This time I made sure it under
1/4 and no draining happened like the last time.
So for the ones that have had the ever draining problem when doing the
filter change I think this will be your answer.
Yea, same here. Someway, somehow, I always end up taking a bath in B11...
Last time the wife made a HUGE mistake and washed a load of clothes with my "filter changing clothes". Nothing more sexy than a diesel smelling pair of women's underwear
I just take my truck to work and put it on the hoist at the end of the day to change it. You get a little bit of fuel but not bad. Then again like everyday I go home with oil and fuel all over me anyway!
