Changing Frame Mounted Fuel Filter
Old Jan 10, 2010 | 03:53 PM
tperk100's Avatar
tperk100
I have changed this filter 3 times and ended up smelling like diesel fuel for about a week. Is there a way to change it (or drain it) without making this mess?
Thanks
Does anyone know where to go to add a signature.. I have looked and looked and cannot find it for the life of me!
Old Jan 10, 2010 | 04:10 PM
jsimon724's Avatar
jsimon724
[quote=tperk100;8348959]I have changed this filter 3 times and ended up smelling like diesel fuel for about a week. Is there a way to change it (or drain it) without making this mess?
Thanks
The drain plug can be changed out with a different style that allows for draining with less mess. Don't know the part # right off, but I believe you can get it from DieselSite.com
You could wear disposable vinyl gloves also.
To add a sig, click on User CP up on the tool bar. Don't know if you need a certain # of posts first.
Old Jan 10, 2010 | 04:15 PM
mhoefer's Avatar
mhoefer
When doing the fuel filter it also helps to have the truck down hill a bit, and less than a 1/4 tank of fuel, better if its < 1/8th and you wont get near as wet. There is also the updated turn out, but, with a lot of fuel in the tank, still get a wet hand, arm, armpit, ect.
Old Jan 10, 2010 | 04:18 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Thanks
Let your tank get down a ways before you change the filter. Parking with the nose uphill helps a bit too.
Old Jan 10, 2010 | 04:21 PM
SteveBricks
FTE Emeritus
Twenty five....
Old Jan 10, 2010 | 04:39 PM
06silvercrew's Avatar
06silvercrew
I cant say this will work on a stock height truck, but my truck I can wedge a funnel between the driveshaft and frame, put a pan under it, remove the plug and never get a drop on me, the ground or the frame/driveshaft.
Old Jan 10, 2010 | 07:43 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
I subscribe to the wedged funnel under the HFCM and a clear used juice jug so I can see the dirt and water that comes out. Here is the upgrade plug...can be purchased many places now...even the dealer has them.
Diesel Technician Society
Old Jan 11, 2010 | 10:15 AM
bpounds's Avatar
bpounds
In addition to all the above:
1. Let the water drain run until it stops. This will minimize the amount of fuel still in the filter housing.
2. Use a 5 gal bucket under the housing. Fumbling around with a funnel must makes a bigger mess. I use wide mouth kitty litter buckets. They are white, so you can see dirt or water.
3. Most of the fuel that gets on you runs down your arm. Solution - keep your arm above the fuel as much as possible.
4. Don't wait a week to take your shower.
Old Jan 11, 2010 | 08:39 PM
cheezit's Avatar
cheezit
I opt to smell like diesel.I so love that smell. its the smell of money. I like money.
Old Jan 11, 2010 | 11:27 PM
tperk100's Avatar
tperk100
Thanks guys,
I am going to install the upgraded plug, and I'll take a daily shower now.
mxz7
Modular V10 (6.8l)
19
Mar 24, 2018 10:59 AM
qman
Jul 1, 2015 05:26 PM
SUPERDUTY_08
Crossovers
May 9, 2012 12:57 PM
Byram
6.2L V8
Feb 24, 2012 06:27 PM
6.0 Rules
Mar 10, 2009 11:37 PM
