Wrench displayed
Old May 5, 2013 | 11:47 PM
Bob2626's Avatar
Bob2626
Wrench displayed
While pulling hard but no fan noise to indicate high temp a wrench suddenly appeared, power backed off (this while I was passing a truck) have checked for any pid displays but there are none.
Stopped and after restart it ran good.
Any one have info on this it would be greatly appreciated.
Thanks, Bob
Old May 6, 2013 | 02:14 AM
RPM371's Avatar
RPM371
Pull the codes. It could be nothing or you may be in the $$$ zone. Can't tell the player without the scorecard.
You also need a Scangauge II to know what's happening under the hood while it's happening.
Old May 6, 2013 | 05:37 AM
bismic's Avatar
bismic
It is always helpful to post the year of your vehicle and any other helpful info (like mods or recent work done).
Common wrench light causes:
oil cooler efficiency (oil cooler clogging up) - not sure if your 2004 would get this one though .
Over boost
low system vloltage
there are a couple of others
There will be (or should be) a DTC stored with this, but many code readers can not pull it. Take it in to get the codes read or monitor your system as mentioned above.
Old May 6, 2013 | 07:02 AM
ul37's Avatar
ul37
Check for codes with the wrench light on before you turn the key off. Sometimes the key cycle will clear the code.
Old May 7, 2013 | 09:03 AM
Bob2626's Avatar
Bob2626
Thanks for the info, I edited the post, maybe it didn't take. Truck is an 05.
I have a scangauge, will try to check befor turn off next time.
Bob
Amicus
Mar 31, 2017 11:53 AM
Markus Steele
6.4L Power Stroke Diesel
Jul 14, 2016 08:16 AM
budneumann
Jul 18, 2012 07:51 AM
claytonc
May 14, 2012 05:25 AM
98SurplusExpy
Apr 9, 2010 04:01 PM
