Wrench Light on .. Need inexpensive code reader for stored codes
Old Apr 2, 2010 | 09:00 PM
98SurplusExpy's Avatar
98SurplusExpy
I got the latest flash the other day per TSB 09-24-3.
Now, after driving maybe 20-30 miles, I'm getting the "wrench light". Truck is not going into "limp mode" ... just displays the light. It goes off after restart, but usually will come back on after another drive.
So since this never happened before the flash, I'm assuming it's one of the three codes/problems that now create a wrench light as a result of the new flash:
  1. Oil cooler efficiency monitor - DTC P012F stored and wrench warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition.
  2. FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when PCM VPWR PIDS is below 10.25V for 60 seconds or below 9V for 4 seconds.
  3. Turbocharger over boost detection - DTC P0234 stored and wrench warning lamp illuminated when a turbocharger over boost condition occurs.
Out of down right fear, I don't even want to start speculating as to which it is. I had the EGR & Oil Cooler replaced less than 1k miles ago (36k miles currently on the clock) before my warranty died due to a title brand, no signs of FICM problems, & no signs of an over boost (truck is stock).
I need an inexpensive code reader to pull the stored code, can't keep paying the dealer $90 for a diagnostic check. I stopped by the local Advance Auto, and either their reader wouldn't do it or the guy didn't know how. How 'bout >>THIS<< Cen-Tech CAN OBD II Code Reader/ EOBD Scanner at Harbor Freight??
Old Apr 2, 2010 | 09:06 PM
cheezit's Avatar
cheezit
you need to find something that can read CAN and OBDII. what you linked is only obdII
Old Apr 2, 2010 | 09:17 PM
98SurplusExpy
Really, This Cen-Tech deal says "CAN OBD II Code Reader" .. that's not what I'm after??
Old Apr 2, 2010 | 09:19 PM
cheezit's Avatar
cheezit
sorry I missed the big blod black type. Man I need new glasses. sorry. that should work fine.
Old Apr 2, 2010 | 10:23 PM
pvanzan's Avatar
pvanzan
Harbor freight sells another CAN OBD II reader that is cheaper than the one you linked to, it is $49.99
Old Apr 3, 2010 | 08:36 AM
gearloose1's Avatar
gearloose1
I have been using this cheapo OBDII reader for quite some time...
Amazon.com: autel maxiscan ms309
Autel Maxiscan MS 309
$50
Old Apr 3, 2010 | 02:15 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Doesn't look like that one is CAN capable.
Old Apr 3, 2010 | 02:26 PM
gearloose1's Avatar
gearloose1
It reads the basic diesel and transmission codes.
Old Apr 3, 2010 | 07:10 PM
solaratomic's Avatar
solaratomic
So a OBDII/CAN capable scanner will read all codes that the 6.0 logs? I thought you had to have the AE software/Ford Bundle to do that. Or does the AE just give you more diagnostic tools like the dealer has ie: cylinder contribution test
Old Apr 3, 2010 | 07:29 PM
gearloose1's Avatar
gearloose1
Hey, if you want "all" the codes... it is available at your friendly Ford dealer.
AE will nearly read a full set, but will not likely have all the sophisticated tests that Ford has... plus the Ford only tips for Ford techs as to what to do, how to do fault diagnostics.
Bargain basement scan tool gets you just that.
Old Apr 3, 2010 | 07:49 PM
solaratomic
Well I've got to start thinking about what to do when my truck goes out of warranty 6/2011. I'd like to consider myself a competent mechanic but, this ain't no gas burner either. As if the part cost weren't enough if you don't have some kind of electronic device to point you in the right direction you're dead in the water. So what I'm trying to do is be able to diagnose and repair problems that arise on my own. To do this I'm thinking an AE is probably gonna be the way to go although I'm trying to find out the difference in capablities of the AE software and a standard scanner.
Gearloose, my ford dealer is not very friendly in that they take a lot of my money and give me very little in return. I know it's hard to beat a GOOD tech, but all that have worked on my truck seem to be just this side of retardation. In all honesty the answer you gave was pretty vague but then so was my question. That's why I clarified it somewhat.
Old Apr 3, 2010 | 08:02 PM
gearloose1's Avatar
gearloose1
If your truck is under warranty... um.. the wrench light is definitely dealer fix territory.
Do nothing to void your warranty.
Talk to the crowd on here that have the AE / Ford diesel package and see what it does for them.
What you are looking for, a feature by feature compare, need to be done with someone who knows the Ford service computer capabilities.. and AE.
Old Apr 5, 2010 | 09:27 PM
98SurplusExpy
Well, the fancy CAN enabled Harbor Freight job will not pull the disappearing "wrench light" set by the latest flash. It says nothings there, even while I'm looking at the lit light before the ignition is turned off.
Old Apr 6, 2010 | 03:16 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
I'd return it... Harbor Freight has a good return policy.
Old Apr 6, 2010 | 07:26 PM
brob1969's Avatar
brob1969
take it back and put the $$ toward the SCT X3
