Sponsored by: Real Truck
Wierd Steering Issue
Old May 15, 2013 | 12:13 PM
thomabb's Avatar
thomabb
Driving with one of the hubs locked in will not cause what you are experiencing. I drove like that for several days once before I found my daughter had not unlocked the passenger hub (prom night story - fodder for a different thread).
The whine is probably your PS pump straining against the frozen U-joint bearing. You will get to the point that fluid will puke out the breather hole in the cap.
From my experience, the problem will continue to get worse until you are afraid to drive the truck.
Old May 15, 2013 | 12:30 PM
EXv10's Avatar
EXv10
Change the joint(s).
Old May 15, 2013 | 12:37 PM
xmontex4's Avatar
xmontex4
good to know, I already called the mechanic and I'm dropping it off tonight for the U-joints, i just wanted to check because i noticed the play in the hub **** and I have had plenty of hub related issues lol. Just didn't want to throw money at the front end like I have done before (4x4 ESOF issue... don't ask).
Old May 16, 2013 | 11:50 AM
xmontex4's Avatar
xmontex4
Just an update, i got off the phone with my mechanic and he said that the u-joints are fine and that he could not get it to happen for him. I had stopped at a red light yesterday and it was yanking me around so i turned the wheel in place and it just went away so that's probably why. He did go on to say however that all 5 of my shocks (stablizer included) are shot and need replacing. He is also going to flush the power steering system to see if there was air in it or something. Also the shocks are the original OEM ones that came with the truck and have been beat on for 97,000 miles so they are definitely past due. Also i guess its extremely out of alignment lol which makes sense because i noticed it looks crooked in the driveway when i think i park it straight.
Old May 16, 2013 | 01:02 PM
EXv10's Avatar
EXv10
I changed my PS pump and oiled the U-joints and it went away. Did you take my advice and make a tight circle with the hubs locked? Also, if you pull onto gravel/dirt you can turn the wheel lock to lock to make it go away. Those joints dry out not wear out so he could easily be wrong.
Old May 16, 2013 | 01:46 PM
thomabb's Avatar
thomabb
If he didn't pull the U-joints out of the truck, he could only check for excessive play. If they are intermittently binding, the only way to check them is to pull them. I had a mechanic clear my U-joints THREE different times. On the fourth trip, I told him to pull them. That's when he found the bearings under the caps had partially disintegrated.
The worn shocks and poor alignment are issues that need fixed, but these are not going to solve your steering issue.
Old May 16, 2013 | 02:23 PM
EXv10's Avatar
EXv10
Yep, they have to really be shot to detect a defective one unless you see red rust dust in them especially on the front ones because they are subjected to much different usage. When I oiled mine they freed up and the jerking went away. Do you have zerks?, if not I can tell you an Oklahoma way of freeing them up.
Old May 16, 2013 | 02:49 PM
xmontex4's Avatar
xmontex4
Ok, I'm going to swing by this afternoon and talk to him. I'm assuming he took them out because he had the front tires off and everything to replace the shocks but that is only an assumption. I had him stop and put the stock shocks back on because i may lift the truck in the next few weeks. I ordered my new rims and tires a few days ago and I'm going to see how well they fit and how high i might want to go before i get an alignment and new shocks. How hard is it to remove the front U-joints? I do not have a press but i might buy one eventually and if it can be easily done then i will remove them myself.
Old May 16, 2013 | 04:05 PM
sammie0126's Avatar
sammie0126
Mine didn't feel bad inspecting on the truck but this is what it looked like inside once removed.
https://www.ford-trucks.com/forums/9...l#post13014341
Old May 16, 2013 | 06:20 PM
EXv10's Avatar
EXv10
Just beat them out with a hammer and sockets (the caps).
Old Jun 10, 2013 | 04:39 PM
thomabb's Avatar
thomabb
So did you ever get to a resolution?? Inquiring minds want to know.
Old Jun 11, 2013 | 07:39 AM
xmontex4's Avatar
xmontex4
Not yet I just got my rims and tires I'm waiting on the stuff for my small lift. I'm going to see what happens after i have new everything before I have him just replace the u-joints. I honestly believe its the u-joints but he insists that its not and admits that he may be wrong he just doesn't want to take my money for something that it may not be. With the 35's on though it stopped just randomly jerking and until this week it has been fine. this week the wheel locked while trying to turn twice but it wasn't hard to force it to keep turning. I am assuming this is because the new tires are much heavier and wider, I have all my stuff minus the rear block, extended brake lines, and front sway bar links in so I'm just waiting on that hopefully by the beginning of next week ill have it and get it installed.
Old Jul 9, 2013 | 07:52 AM
  #28
xmontex4's Avatar
xmontex4
I got my lift put in over the lift put is over the weekend and found out that one of my lower ball joints is completely shot. Thought that was strange because I thought I had the upper and lower ones replaced 2-3 years ago, could that potentially cause the issue as well?
Old Jul 9, 2013 | 08:05 AM
  #29
thomabb's Avatar
thomabb
I wouldn't completely rule it out, but odds are no. Did you have odd tire wear?
Old Jul 9, 2013 | 08:35 AM
  #30
xmontex4's Avatar
xmontex4
Yes my old tires had a weird wavy pattern worn into them from back when my dad go them about 4-5 years ago. Long story short he went through 3 different sets and they were all replaced under warranty because they got bad wear patterns after a week. The most recent set didn't start to wear bad until a year after he bought them. My new set of tires hasn't had the issue except for the one time the steering wheel locked up and i forced it.
