Old 11-20-2014, 06:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
  • Window Tinting
    Important information to help you understand your Ford truck
Browse all: Exterior Guides
Print Wikipost
My $20 window tint project
Old 04-22-2013, 07:37 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Well, actually.....it turned out to be $60 total since I did all three of my trucks at once ($20 for a pair of windows). The rear doors and back glass were already tinted so I only needed to tint the two front doors. I found a place online that sells window tint pre-cut to shape. The computer plot was perfect and the pieces fit really nice. The film seemed like good quality stuff as well.
I think I will use them again if I ever have the need.
PrecisionCutTint.com - Automotive Precut Window Tint Kits
In the past, I have found that knifing the film was always the hardest part for me because I wouldn't cut deep enough and end up tearing the tint by accident. So, having it pre-cut to your particular vehicle made the installation super nice. If you decide to try this yourself....resist the temptation to trim the piece....it will fit perfectly without any trimming. The excess material on the left and right sides will tuck neatly behind the felt channels. Keep in mind the visible opening of the glass is wider when viewed from outside so you need to look at it from that perspective to make sure you have full coverage.
I will try and upload some pics.
EDIT: The photos should appear stacked....if they appear side by side then shrink down the size of your screen (left to right) so the photos are stacked. They will make more sense that way.
Old 04-22-2013, 07:39 PM
Shake-N-Bake
A few more pictures...
Old 04-30-2013, 09:15 AM
Carlene's Avatar
Carlene
Carlene is offline
Admom
Very nice.
How do you get the tint to fit so nice at the bottom of the window? I think that would be the difficult part.
Old 04-30-2013, 12:40 PM
Shake-N-Bake
Originally Posted by Carlene
Very nice.
Since the door panel comes off so easily (about 2 minutes...), I decided to go ahead and remove them. Then I just let the tint run long down into the door channel. The folks who sold me the tint sent over some great links to online videos that show an alternative method of applying the vinyl without removing the door panels. I guess this would be helpful for those vehicles where removing the panel is a pain.
Here are the links:
Side glass:
Back glass
Shrinking
Installing
Old 06-27-2013, 07:42 AM
BEARDOWN's Avatar
BEARDOWN
BEARDOWN is offline
Nice! Reps for you!. Would you say the 30% matches the factory tint well?
Old 08-20-2013, 12:15 AM
wastingas's Avatar
wastingas
wastingas is offline
Nice work. I buy the Black magic tint from walmart. its about $6 a window, I know what your saying about ripping the tint, its very important that you get a good NEW razor I get the titanium tipped blades that cost an extra buck.
Old 08-20-2013, 09:03 AM
CarlT100's Avatar
CarlT100
CarlT100 is offline
Looks really good. Nice work and thanks for the detailed instructions.
Old 08-20-2013, 11:20 AM
Shake-N-Bake
So far the tint job is holding up great!
However, I've learned the tint supplier has a premium grade product available. It's a little bit more expensive but I'd probably choose the premium grade if given the choice to do it over again. I think the premium grade has more UV protection and is more forgiving material to work with.
Old 06-06-2014, 02:33 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is online now
Received 3,385 Likes on 1,776 Posts
I tried to rep you, but apparently I've repped you a time or two too many before. So I'm bumping this thread instead, so others can rep this great post with well annotated pictures. Besides, summer is here, which means it's Tintn Time.
I need to redo my removable tint and reapply something better. Besides, tint will contribute to making the cab more silent.
Come on guys It takes a LOT of time to not only interrupt what you are doing every 3 minutes in order to take in progress pics, but to also load the pictures into paint and annotate them with text and arrows arranged to make clear explanations prior to uploading. Write ups don't get any better on an online forum than what ShakeNBake has put up here in this post. Rep him if you can!
dne99fa
1999 to 2016 Super Duty
13
10-08-2010 09:36 PM
hp246
07-18-2010 09:24 PM
teerex
1997-2006 Expedition & Navigator
07-10-2009 11:57 AM
89bronc
09-25-2008 01:36 PM
Holmesuser01
01-12-2005 07:28 PM
Quick Reply: My $20 window tint project
