Anyone have this D-Max muffler
Just doing some "research" as my 300 rebuild is approaching and came accross this. Does it really fill the need for an X-over? Its only $130ish on amazone.
Dynomax® Performance Exhaust | Mufflers | Ultra Flo™ X Mufflers
I don't own one but that looks like a good muffler I generally prefer the sound of glass filled mufflers like that, and yes it would do the trick.
That said however you don't need it, your better off with a 6 merging them in to a Y-pipe and large single to the muffler. It's both better sounding, better flowing and fits better under the truck then 2 pipes.
EDIT; What kinda sound ya going for and do you want dual outlets?
I'm not a 300 expert, and I'm surprised one hasn't chimed in yet. But I've done a fair amount of exhaust work. And in general the sooner and longer the flows come together the smoother sounding(less sharp tones and more rumble instead) within reason of course. Also the more equal the pipes are between the head and where they merge the smoother the sound.
I would think a early well done Y-pipe to a single 3" "glass pack" out to a single 3" or 2.5" tailpipe would give a real nice rumble. Just my opinion though.
2 piece headers are great on these engines as they are naturally 180deg headers. In which case there is a real benefit to keeping the 2 sections separate and as equal length as possible for 2-4'. By keeping them separate the exhaust pulses are more spaced in each pipe allowing one pulses momentum to help better pull the following pulse. After about 4' from the collector this though tends to add a restriction in the 2.5" pipe and the more spaced pulses add to a sharper exhaust tone. This is where keeping them equal length comes into play, if the 2 pipes are exactly equal in length then the 2 sides can come together smoothly and the pulses merge like a zipper. At this is where the simplest and quietest answer is a dual inlet 3" single outlet muffler on out to the tailpipe. But IDK if you guys will believe me but if kept equal bringing the 2 sides together evenly and smoothly will have a real quieting effect possibly making a large muffler unnecessary.
However the super awesome thing for Joe the welder to fab up would be to add a couple of venturis/steps, and a hi flow y-pipe to the system. Using a venturi at the merge points at both collectors and Y-pipe can help speed the gasses and lower pressure at the tail end of each pulse helping in pulling out he next. And stepping to 3' from 2.5' at the tail end of the 2-4' and then to the Y will have a similar effect.
Additionally this is the time to add exhaust crankcase scavenging to replace the effect of the PCV valve at high throttle low vacuum conditions.
