The Leaky Head Thread
Old Mar 12, 2013 | 12:37 AM
  #46
TheKirbyMan's Avatar
TheKirbyMan
Manifolds
Old Mar 12, 2013 | 01:20 AM
  #47
bruno2's Avatar
bruno2
That would do it!
Old Mar 12, 2013 | 01:38 AM
  #48
TheKirbyMan
If your headers would fit a little 302 I would trade you my manifolds...
Old Mar 12, 2013 | 10:12 PM
  #49
jasonhambrick's Avatar
jasonhambrick
Exhaust gaskets
Check these out. They may help.
JEGS Copper Exhaust Gaskets - JEGS
Old Mar 12, 2013 | 10:16 PM
  #50
Gary Lewis's Avatar
Gary Lewis
Jason! Welcome to FTE! Those gaskets look great. If Bruno ordered them tonite we might could have them Saturday. I'm trying to have things sorta ready so maybe between Sat and Sun afternoon we can get it going.
Old Mar 16, 2013 | 12:07 AM
  #51
bruno2's Avatar
bruno2
OK was considering just buying a new set of plugs instead of sandblasting the old ones. I will probably eventually blast them , but, not now. World products recommends:Spark Plug: 14mm 5/8" .460" reach tapered style, Accel 276 or 276S or equivalent. I believe the "S" designation is for short and would probably work best with the header application.
However, I am not a fan of accel. I crossed them last time and came up with the NGK UR4 plug which happens to be my favorite brand. Here is a list of what crosses with the Accel 276S:
Bosch HS7E
Champion RDJ7Y
Champion DJ7Y
Denso T20MPU
Denso T14PR-U
Denso stk 5020
NGK 1270
NGK BPM6F
NGK UR4
NGK 5950
NGK BPMR6F
NGK stk 6630
Now all of these cross with all kinds of stuff if you click on them. The NGK UR4 crosses with about a dozen Motorcraft plugs. I am not sure if anybody offers a short variant like accel though.
Give me your thoughts and opinions please.
Old Mar 16, 2013 | 01:39 AM
  #52
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm a big fan of NGK.
BPM6F converts to; 'B'=14mm, 'P'=projected electrode, 'M'=compact, 'nothing'=9.5mm/3/8" reach, '6'=heat range (of 2=hot -->11=cold), 'F'=tapered seat.
The 'R' variant is a resistor plug, for if you have copper plug wires like Packard 440 cable and electronics that would have interference.
I have the naming conventions for NGK spark plugs bookmarked.
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
The Motorcraft AF42 or AF52 have a 'C' (compact) variant also.
Old Mar 16, 2013 | 01:43 AM
  #53
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A .460" reach .044" gap plug would be BPM6FS-11 in the NGK nomenclature.
But I don't see it offered.
The 1270/5950 are stubby (think weedeater) 3/8" reach type plugs as well.
Generic photo from Amazon,
Old Mar 16, 2013 | 08:18 AM
  #54
Gary Lewis's Avatar
Gary Lewis
Good info. Somewhere I have seen a chart that explains the Motorcraft numbering convention, but can't find it. I did find a cross-ref to ASF42C on one of those plugs and was trying to decode it.
Old Mar 16, 2013 | 08:42 AM
  #55
bruno2's Avatar
bruno2
I can get the 1270. 8 of them should be here Monday. Well at Advanced Auto for me to pick up. I like NGK as I stated above my favorite. Then probably Champion or Motorcraft. Bosch and Autolite fall at the bottom of the list.
Old Mar 16, 2013 | 09:37 AM
  #56
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
1270 is only a 0.375" (3/8") reach plug.
Old Mar 16, 2013 | 12:56 PM
  #57
bruno2's Avatar
bruno2
Is that bad?
Old Mar 16, 2013 | 01:03 PM
  #58
bruno2's Avatar
bruno2
Jim ,was the plug you dissected in your post the proper one?
Old Mar 16, 2013 | 01:04 PM
  #59
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Post 51, you say you want a .460 (7/16") reach plug...
No, like I said in post #53 you would want 'FS' before the heat range number.
Old Mar 16, 2013 | 01:10 PM
  #60
Gary Lewis's Avatar
Gary Lewis
Originally Posted by bruno2
Is that bad?
Yes, if you need a .460 reach then using a shorter plug will shroud the tip so that the spark won't be as effective. And, if it is short enough to expose threads in the head you will have hot spots that contribute to detonation.
