The Leaky Head Thread
Old Apr 7, 2013 | 09:19 PM
  #181
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Okay, so I went back and checked.
9.45:1 compression and a #6 plug is about mid way on a scale of hot 2--> 11 cold.
We would run BP7ES in air cooled twin motorcycles, like a Norton Combat.
If it seemed okay in that, I can't imagine a #6 plug would be a problem in a water cooled engine.
Old Apr 7, 2013 | 09:26 PM
  #182
Gary Lewis's Avatar
Gary Lewis
We didn't polish anything, but there were no sharp edges. I looked. And, we are at 6˚ BTDC as Bruno said. In fact, we checked the timing indicator against the balancer using a dial indicator to find TDC and it is dead-on.
Another symptom is the way it cranks. Or, maybe I should say the way it kicks back. Today when Bruno first cranked it the engine spun nicely. Just as he let off the starter it fired a bit but didn't catch. When he hit it again it went UGH and stopped spinning for an instant and then spun and started. Keep in mind that he has MSD (sounds like a disease) and I doubt it has any retard built in for starting.
  #183
bruno2's Avatar
bruno2
Originally Posted by 85lebaront2
I hope they polished all the sharp edges in the combustion chambers. That will give you all kinds of detonation.
I am not sure. A good machinist has had his hands on these heads twice now them all the way apart and nobody said anything about places needing polishing. The odd thing is that I cant remember the truck acting this way the first time it ran before the head gasket failure. Now I can hear something like back fires or something when I flog it down low. I am writing it off as plug wire issues for now, but I hope I am not having detonation issues and I hope that wasn't what caused the head gasket failure the first time.
Old Apr 7, 2013 | 09:28 PM
  #184
ctubutis's Avatar
ctubutis
Originally Posted by Gary Lewis
...and we'll "throw the Bronco on the trailer". (Had to reinforce that point just to needle the moderate guy.)
Old Apr 7, 2013 | 09:29 PM
  #185
bruno2's Avatar
bruno2
If it seemed okay in that, I can;t imagine a #6 plug would be a problem in a water cooled engine.
Jim I am running an accel 276S plug this go around. It is what the head manufacturer recommended. I was running an NGK UR4 I believe.
Old Apr 7, 2013 | 09:31 PM
  #186
Gary Lewis's Avatar
Gary Lewis
The only way you could be having detonation is if those heads are much smaller than we think. We should have CC'd them to make sure, but they don't look small. And, you haven't driven it long enough for it to get completely hot. Further, you don't have anywhere near full throttle (it'll only go 35 MPH) and it usually takes lots of throttle to get detonation on an engine with no vacuum advance.
Old Apr 7, 2013 | 09:32 PM
  #187
Gary Lewis's Avatar
Gary Lewis
Originally Posted by ctubutis
It worked!
Old Apr 7, 2013 | 09:34 PM
  #188
bruno2's Avatar
bruno2
Maybe that's what was happening when the gasket went. You and I were messing with the carb because it was running out of fuel on the top end. So I was running it really hard up the on ramps on HWY 75 when the gasket went.
Old Apr 7, 2013 | 09:35 PM
  #189
bruno2's Avatar
bruno2
It worked!
Old Apr 7, 2013 | 09:46 PM
  #190
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Bruno, That 276s plug crosses to a heat range 6 in NGK.
I don't think that is the issue... unless you sealed them with silicone and the heat can't get out of the plug and into the head!
Maybe you're just jetted too lean?
Old Apr 7, 2013 | 09:52 PM
  #191
Gary Lewis's Avatar
Gary Lewis
Originally Posted by bruno2
We needled the surfer dude.
Old Apr 7, 2013 | 09:55 PM
  #192
bruno2's Avatar
bruno2
Is this a reference to how they treated his p/u bed you shipped?
Old Apr 7, 2013 | 10:03 PM
  #193
Gary Lewis's Avatar
Gary Lewis
You mean the bed I should have kept? No. He just doesn't like slang like "throw the engine in" or "throw the Bronco on the trailer". Would rather we be more precise and take 8 pages to explain how we will first start it up, put it in 4lo, ........ and finally secure it tightly to the trailer in 6 places.
Old Apr 7, 2013 | 11:46 PM
  #194
ctubutis's Avatar
ctubutis
That is correct. Euphemisms such as "throw it on" imply a lack of professionalism, concern for correctness & quality, and can suggest unsafe procedures and end results.
Just my opinion.
That's a bit much but be verbose if you need to, I certainly am sometimes. However, I didn't earn the title of King of the 8-page microanalysis, so....
Old Apr 8, 2013 | 01:31 AM
  #195
FordFETruck's Avatar
FordFETruck
I thought it was 80 page micro analysis?
