The Leaky Head Thread
Old Apr 8, 2013 | 04:15 AM
  #196
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
'Dad's Truck' is going on 190 pgs, and will surely hit 200 by the time it is running again.
Old Apr 8, 2013 | 09:43 PM
  #197
bruno2's Avatar
bruno2
OK , Jason has some questions about the Bronco and I don't know the answers. He was wanting to know what the total advance is on the timing. Also he is wondering if the dizzy has too light of springs in it because he doesn't think it should be pinging at 6°BTDC. I told him I have no idea if we even looked at the total advance.
Gary, do you remember if we checked total advance?
Old Apr 8, 2013 | 09:48 PM
  #198
Gary Lewis's Avatar
Gary Lewis
No, we didn't check the advance at all. But, the springs aren't so light that the advance is coming in at idle or even a bit above. It is rock steady at 6˚ at idle and with the lope it has if the springs were letting the advance come in the timing would not be steady. It looks like the engine isn't even turning it is so steady.
Old Apr 8, 2013 | 10:36 PM
  #199
jasonhambrick's Avatar
jasonhambrick
I agree with Jim. I think it may be lean.
Old Apr 8, 2013 | 11:44 PM
  #200
bruno2's Avatar
bruno2
Well then I can check that out whenever the carb job comes back around. For the time being I am sick of working on this thing. I need to do some stuff to the F250 to get it back to legal to drive. I am trashing my good truck out because the F250 is too shady to drive with its one headlight and no tail lights.
Old Apr 9, 2013 | 05:03 AM
  #201
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Stock spec's mean nothing with a cam, aftermarket heads, exhaust, etc....
http://www.cranecams.com/uploads/ins...2e_%281%29.pdf
You need to play with one setting at a time, or spend some $ on the Dyno.
Old Apr 9, 2013 | 06:42 AM
  #202
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
The question comes, what conditions is it pinging under, RPM load etc. To really set a distributor up you need a distributor test machine, one that will work with a DS-II system. If you are only running mechanical advance (no vacuum) then most Ford small blocks like 36-38° total advance. Where it comes in may be the problem. The GT-350 I used to own had an interesting curve, it was mostly in at 3000 rpm, but continued to advance until 5000 rpm.
Old Apr 10, 2013 | 09:59 PM
  #203
bruno2's Avatar
bruno2
Ok , so tonight Jason and I went to look at the timing again. I tried to start it and it wasn't cooperating. I was cranking it over and I guess the ignition switch took a crap on me. The lock cylinder is just flopping around and not starting the truck. It seems as though the actuator rod isn't attached or something. So another hurdle to jump trying to get it going again.
Old Apr 10, 2013 | 10:02 PM
  #204
Gary Lewis's Avatar
Gary Lewis
Do you have a tilt wheel? The tilt steering wheels, at least in the 80 - 86 era, are notorious for having a piece break in the linkage. I've heard that the HELP section in the parts stores has the part, but I don't know that for sure.
Old Apr 10, 2013 | 10:08 PM
  #205
bruno2's Avatar
bruno2
Yeah its a tilt wheel. That came with the cruise package. Hopefully someone will post a link with the part description.
Old Apr 10, 2013 | 10:21 PM
  #206
Gary Lewis's Avatar
Gary Lewis
I don't know what part breaks. I could post an exploded view, but wouldn't know which part is the one that breaks.
Old Apr 11, 2013 | 03:06 AM
  #207
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ask, and you shall receive.
Dorman 83280
http://www.dormanproducts.com/p-9625-83280.aspx
Here's a thread; https://www.ford-trucks.com/forums/9...on-switch.html
And an image from JBG that can be found in that thread...
Sounds like Pam is 'a hot mess'
Old Apr 11, 2013 | 07:52 AM
  #208
bruno2's Avatar
bruno2
Thanks for the replies. I guess I have to figure out how to take the steering column apart now.
Old Apr 11, 2013 | 08:22 AM
  #209
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Oh, and just FYI Gary.
The Dorman page shows that part '80-'92.
Old Apr 11, 2013 | 09:56 AM
  #210
Gary Lewis's Avatar
Gary Lewis
Thanks, Jim. That helps a bunch.
