The Leaky Head Thread
Old Apr 11, 2013 | 12:27 PM
  #211
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Check that the gear on the back of the key cylinder is okay first.
It is a LOT easier to get to and/or replace.
Old Apr 11, 2013 | 10:17 PM
  #212
bruno2's Avatar
bruno2
Whatever the problem is the ignition switch powers up everything , but it wont do anything in the start position. No spring action or cranky. The cylinder just rolls into that position with no resistance at all.
Old Apr 11, 2013 | 10:30 PM
  #213
Gary Lewis's Avatar
Gary Lewis
It might actually be the switch then. As you probably know, the switch itself sits on top of the column about a foot or so back from the firewall. I'm not sure if you can get to it w/o dropping the column, but that isn't all that difficult - I just did it. Pull the collar on the column and the trim piece and pull the bolts going into the dash.
Old Apr 12, 2013 | 03:08 AM
  #214
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Oh, I didn't realize what you meant when you said "floppy"
Typically when the rod breaks it won't pull the switch back to the off position.
Old Apr 12, 2013 | 03:11 AM
  #215
FordFETruck's Avatar
FordFETruck
I hope that piece on mine never breaks, although I did have an ignition switch grenade on me, I could barely get the key in sometimes and when I would start it would be one hell of a fight to get it back off the starter engage position. Replaced it with a $10 ignition lock and that was the end of that, new one's been working perfectly for months now.
Old Apr 12, 2013 | 07:37 AM
  #216
bruno2's Avatar
bruno2
Does that sound more like the switch now?
Old Apr 12, 2013 | 07:48 AM
  #217
Gary Lewis's Avatar
Gary Lewis
If turning the key makes something happen with the switch then the part isn't broken, or at least not completely broken. And, being pot metal one would think that there isn't any "partly broken", that it would be fine or broken, nothing in between.
But, I don't know where the spring is that brings things out of Start and into Run. IOW, whether there's a spring in the mechanism or the switch, or both. It sounds like there may be one in the switch itself and the switch is broken. Let's see what others say.
Old Apr 12, 2013 | 08:20 AM
  #218
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The switch is spring loaded to return to 'run'
Old Apr 12, 2013 | 09:58 AM
  #219
1986F150six's Avatar
1986F150six
I have a friend who is a FORD technician. He is about 6' 7" tall and BIG. I was amazed to see him crawl between the bench seat and steering wheel and change the switch on a F150 in less than 10 minutes [by my watch]!
Old Apr 12, 2013 | 09:43 PM
  #220
Gary Lewis's Avatar
Gary Lewis
I'll bet he's done it before. Several times. If you know how to get the connector out it might not be a big deal, but that connector can be a bear.
bruno2
18
Jun 10, 2012 04:47 PM
fishin machine
15
Feb 2, 2008 07:39 AM
Reidicus
Sep 12, 2006 07:46 PM
Narwhal
15
Feb 18, 2006 04:25 PM
Night Rider
1997 - 2003 F150
Jun 7, 2004 03:46 AM
