so the truck has still been running ok, just seems to be losing a litlle power of late and having trouble cold starts. Havent worried much as have been sorting out other stuff. So i had a spare minute this morning and hooked up the AE, this is the result, still getting same codes as original. All injectors buzz at same tone which i can here in the cab easily, tried to do a koer test and it stalls the engine
plus this is the cold start video
ICP is my first suspect... and I don't mean by a small margin. That P1210, plus the fact that it's a locally-supplied part, plus the lope, plus the smoke screams yank it. Oh wait... "Yank" is slang for American down there. Remove the ICP and get a proper one. I say this while assuming you've already cleared your codes with AE before that popped up again.
Cleared the codes over and over again!! I bought injector o rings a while back but never did em cause I didn't get uvc wiring, was gunna replace at same time. So will get order from clay and get both save postage
