Powerstroke starting issues
Old Oct 8, 2012 | 03:42 PM
DanielT28's Avatar
DanielT28
I have a 97 5 speed power stroke. I bought it a few months ago and the guy said it had new glow plugs. Anyways at random ill start it up than it'll just die after a few seconds. Now i had it stared for about 3 minutes and it just died. Now just cranks over won't start. Any suggestions ?
Old Oct 8, 2012 | 03:54 PM
msmenne17's Avatar
msmenne17
Start by replacing your CPS (Crank Position Sensor). Do NOT get an aftermarket (Aka big box store). Get it from Ford or International. The parts store ones do not last very long (6 months). I've read it here and experienced it for myself.
My CPS went out last winter at random. I couldn't start the truck most of the winter. I hadn't been driving it much. I figured it was bad Glow Plugs or GPR. When it finally warmed up, I changed the CPS and voilla!! It started right up.
Hussler's Avatar
Hussler
Does the "wait to start" light still work?
Does the "tachometer" move when cranking?
Since it ran for 3 minutes before dieing check the fuel bowl and see if it is full or empty.
Old Oct 8, 2012 | 03:57 PM
DanielT28's Avatar
DanielT28
I did replace the CPs with one from O'Reilly. But I'll get one from ford. My brother is using the truck right now and he called me with the problem. So I'll have to ask him
Old Oct 8, 2012 | 04:06 PM
msmenne17's Avatar
msmenne17
It isn't uncommon for them to be bad out of the box. My experience is typically that the big box store ones just don't last as long.
Old Oct 8, 2012 | 04:07 PM
DanielT28's Avatar
DanielT28
Well I've had it on there for about 3 weeks. Maybe even more and it seemed to be doing fine. But now it's dying. Or just cranking >
Old Oct 8, 2012 | 04:55 PM
fordpride's Avatar
fordpride
Put a good CPS in
Old Oct 8, 2012 | 05:10 PM
DanielT28's Avatar
DanielT28
They're only 30 bucks. I'll try it
Old Oct 9, 2012 | 11:21 AM
DanielT28's Avatar
DanielT28
Ended up being the fuel heater fuse
Old Oct 9, 2012 | 07:31 PM
Ken_C's Avatar
Ken_C
Been running the same CPS from autozone for about 4 years now.
Old Oct 9, 2012 | 11:00 PM
msmenne17's Avatar
msmenne17
From everything I've read and experienced, you're lucky.
Old Oct 10, 2012 | 04:43 AM
stainlessstroker95's Avatar
stainlessstroker95
Did you unplug the heater or replace it so it doesnt happen again?
Ron Richardson
Oct 27, 2012 05:37 AM
parkland
19
May 15, 2008 02:47 PM
dmueller71
36
Jun 17, 2007 06:29 AM
IMRAY69
Mar 19, 2006 08:11 AM
palajoe
Mar 4, 2005 10:06 AM
