Throttle cable help - 1966 F100
Old Feb 12, 2013 | 03:19 PM
Honeybadger's Avatar
Honeybadger
Hey All, I've just installed a 1966 289 (out of a 1966 Bronco says the guy I bought it from) in my old F100 which did have the smaller 6 from what I've been told. I'm not sure how to rig up a new throttle cable or which one to get. It looks like the 6 cylinder cable came right through the firewall straight to the carb, but the 289 sits about 4-6" to the driver's side of the engine bay. I'm not sure if the 352 V8 cable would work and would have the same offset or not. I'm tempted to buy a 14" Ford cable, but this wouldn't address the offset. Any ideas?
Old Feb 12, 2013 | 04:37 PM
66f-100's Avatar
66f-100
The 352 cable would probably work better, but you also need the bracket that mounts on the intake and holds the cable.
Old Feb 12, 2013 | 08:06 PM
Honeybadger
Thanks for the advice!
Old Feb 12, 2013 | 08:07 PM
C G B's Avatar
C G B
Pictures are worth a 1000 words. With the proper bracket almost anything can be made to work as long as your happy how it looks. I think the 352 cable will work fine, providing you have the right bracket.
Old Feb 13, 2013 | 07:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-9A758-AH = 1965/66 F100/250 352 accelerator cable is 20.00" long and has been reproduced.
Old Feb 13, 2013 | 07:27 AM
Honeybadger
Thanks guys. I read on another thread about using a steel rod to make the offset with a bend, and using heim joints for the ends. I'm not sure how the heim joints would hold onto the post unless a clip of some kind was used. I measured the distance from the firewall to the carb and its about 12" with about 2" inside the cab. That would be about 14" and I'm not sure what 20" of 352 cable would do. Thanks for the advice. You guys are awesome!
Old Feb 13, 2013 | 12:06 PM
daveengelson's Avatar
daveengelson
On my 65 with T18 (4spd) went to direct machanical linkage. Never had an issue since installing in 72. Perhap other members who have gone with the 289 swap will chime in with suggestions??
1965 Ford F100 4x2 - Machanical Throttle Linkage
https://www.ford-trucks.com/user_gal...153992&width=0
Old Jan 5, 2015 | 01:38 PM
Acarhauler's Avatar
Acarhauler
1966 4x4
I have a 1966 f100 4x4 heavy duty suspension. I am the actual 3rd owner of this truck. It needs a lot of work but runs great. The drivetrain is in excellent condition. It has a 300 6 cyl 1 bl carb, I need a throttle cable. I would love to find a new one but not holding my breath. I am trying to find a universal kit that I can rig up until I can search some salvage yards I know of. Any one got a better suggestion on how to proceed?
Old Jan 5, 2015 | 02:03 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If this is a factory 1966 F100 4x4 then the original part number would likely be
C5TZ-9A758-AE
There are none available new at this time that I can find online. I probably bought the last NOS one in existence some time ago. I'll look in the archives to see if I can find it.
If you search on the part number there are a few threads and one common recommendation is to try a Lokar kit.
I hope that helps some.
Old Jan 5, 2015 | 02:31 PM
TxStang2010's Avatar
TxStang2010
a cable a bit longer than you measured would be better so that it has sweeping curves that will not bind .
Old Jan 5, 2015 | 03:01 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I agree. The stock cable was 26.06" long and makes a smooth curve from firewall to carb hookup. The 6 cylinder with the 1bbl carb has a side-to-side throttle movement rather than the front to back movement of the 352 V-8 so it is quite a bit of a stretch over to it.
Old Jan 5, 2015 | 03:13 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If you go to my post #133 in this thread you can see a picture of the NOS C5TZ-9A758-AE. At least gives an idea of what it should look like. My original still works fine, too, just some signs of age like yellowing on the plastic end near the carb.
https://www.ford-trucks.com/forums/1...250-4x4-9.html
Schuyles
May 24, 2012 03:23 PM
Marty in PA
Apr 30, 2012 07:07 PM
ford66
27
Dec 23, 2011 10:25 PM
65toy83beast98exploder
Apr 7, 2003 11:02 AM
frank_1
Aug 18, 1999 07:07 PM
