65 throttle cable
Old Aug 16, 1999 | 03:13 PM
frank_1's Avatar
frank_1
65 throttle cable
i need a good solution for an old problem. i have converted my 352 to a four barrel carb. i have just worn out my second cable in twenty years of owning this truck. the new cables are no longer avalible from ford. has anyone had to confront this problem? i have not yet found a source for a new cable.
Old Aug 16, 1999 | 06:37 PM
jowilker's Avatar
jowilker
65 throttle cable
You can find one in the junk yards, should be cheep, Get two.
John
Old Aug 17, 1999 | 10:14 AM
frank_1's Avatar
frank_1
65 throttle cable
no can do! i know every junkyard old f-100 in town.
Old Aug 17, 1999 | 10:55 AM
jowilker's Avatar
jowilker
65 throttle cable
Frank, I was trying to tell you nicely of course, you aint gonna find a new one. OK. I suggest maybe you try a salvage yard.
John
Old Aug 17, 1999 | 11:05 AM
Jeff's Avatar
Jeff
65 throttle cable
Frank,
In the past few weekends I have picked up some nice '67-'72 parts from a couple local wrecking yards here in the Pacific NW. Between the two, they must have about 40 trucks to pick from.
Is this the throttle cable your talking about? What should I pay for these if I get a few? Where does it wear so I can check them before I buy?
If I can get one, you can have it for cost plus shipping. You should see the almost perfect original bench seat and dash pad I picked up ($50 and $40 each)! Like I've said before, it seems as if everyone has one of these old Fords in their yard or driveway out here. Most have moss growing on them from sitting in the rain. Don't ever move here, it rains ALL OF THE TIME!
Old Aug 17, 1999 | 12:26 PM
frank_1's Avatar
frank_1
65 throttle cable
jeff, thanks for the offer, the truth is i have never had much luck with the wrecking yard cables. yes were talking throttle cables. i bought one new from ford in about 1983. i had owned the truck about three years at that time. so i would say from my experience that these cables have about a 20 to 15 year life span (im not considering milage here) yes the one used cable i had did not last very long. i was hopeing to find some one who had solved this problem or knew some source where i could get a new one. if you do buy one for yourself, don't pay more than ten dollars for one. i think it would be a good idea to get more than one.
Old Aug 17, 1999 | 03:02 PM
frank_1's Avatar
frank_1
65 throttle cable
john, thanks, but isn't that what you said the first reply? ALL my salvage resources are done here. if i do find an original in a wreck, usually the darn thing crumbles in my hand.
Old Aug 17, 1999 | 05:02 PM
jowilker's Avatar
jowilker
65 throttle cable
Frank, I have some cables that are 33 yrs. old and are still working fine, in different trucks.
John
Old Aug 17, 1999 | 06:46 PM
Charles's Avatar
Charles
65 throttle cable
My '65 F-350 (4-speed) originally had a rod connecting the lever sticking out of the firewall directly to the stud on the carb. The ball sockets are no longer available, and the previous owner had used baling wire for a linkage. I removed the stud and used a piece of 1/8" welding rod with 90 degree bends at the end, and those weird-shaped linkage clips to hold it. Works perfectly, and allows enough slop sideways for engine movement without binding.
Old Aug 18, 1999 | 07:07 PM
Charles's Avatar
Charles
65 throttle cable
Wrangler41
Mar 28, 2017 04:07 PM
powerstroker100
Aug 17, 2015 01:16 PM
Daewoo
Feb 13, 2012 10:44 PM
Mike04ranger
1983 - 2012 Ranger & B-Series
13
Jan 19, 2011 09:43 AM
swaybar
15
Dec 21, 2009 05:13 PM
